engine ticking
Old Mar 5, 2011 | 01:54 PM
86z28Dave's Avatar
engine ticking
Hi i have a 350 tbi and when you start it its fine for about 20 minutes but once warm and usually on the highway i get a nasty ticking noise and loose most of my power. if i turn it off and let it cool its fine again until it is at running temperature again. oil is fine temp is fine. Could it be my injectors? i cant feel the noise when i put my hands on the injectors what else could it be?
Old Mar 5, 2011 | 02:19 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: engine ticking
well oil is fine but is the oil pressure fine? oil warms up thins up a bit, then any loose components show. Even lifters can do that also. make noise as they are warm.
Old Mar 5, 2011 | 04:42 PM
ex-x-fire's Avatar
Re: engine ticking
I guess if its loud enough, it could cause the knock sensor to retard the ign. timing. I'd pull the valve covers & check for loose rockers, is this 350 from a truck? Might have a flat tappet cam. Might have worn lobes.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 7, 2015 09:55 PM
