knock sensor Q
Old Mar 6, 2011 | 01:15 PM
Chadmon's Avatar
Car: 92 Camaro RS
Engine: 305tbi
knock sensor Q
So im using a 1973 350 truck block with my 305's TBI setup and i have no idea which knock sensor to use? also are there any heads that i can get for cheap and build that will work with this setup that are better than my 305 heads or the old 73 truck heads?
Old Mar 6, 2011 | 02:09 PM
ex-x-fire's Avatar
Re: knock sensor Q
I'd read the sticky on the 350 swap, I guess you could get away w/ the stock sensor & see how it runs. Especially if your not running high compression ratios.
I guess a good set of cheap heads would be some vortecs, but they require a vortec intake & gasket set. You can get a vortec 4bbl. intake very reasonably & use a tbi adaptor. Those heads flow better then any stock chevy heads & almost as good as the LT1 heads from the 90s.
305 heads on a 350 block will boast your comp. ratio.
Old Mar 6, 2011 | 07:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: knock sensor Q
You need a 350 knock sensor. You'll also need 350 injectors, a 350 TBI prom chip (from a caprice or truck). You might also need a VATS bypass module - your VATS sends a 30Hz signal to the ECM, a 350 ECM might be looking for another frequency (there were 2 signals, 30 Hz and 50 Hz) - this is of course if you use a 1989 or later 350 TBI prom chip, pre-1989 no VATS, so no VATS issue.
Old Mar 6, 2011 | 11:23 PM
Chadmon's Avatar
Car: 92 Camaro RS
Engine: 305tbi
Re: knock sensor Q
I understand that it needs to be a 350 knock sensor lol, but there are different 350 knock sensors correct? sorry for the confusion.
Old Mar 7, 2011 | 05:18 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: knock sensor Q
Hope this helps https://www.thirdgen.org/forums/tbi/...ck-sensor.html
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
