opinion on roller pushrods with tappet lifters
Old Mar 8, 2011 | 11:12 PM
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
as some of u know in my recent post im doing a cam swapp i got the cam timing chain lifters and valve springs
roller motor flat tappet cam
want to know opinions for the followin
will roller pushrods work with the tappet cam and lifters? (right measurements etc. .)
plz help i wanna have everything for this
just want opinions ive been hearing mix things. . . ..
Old Mar 8, 2011 | 11:15 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: opinion on roller pushrods with tappet lifters
let me rephrase his question. can he reuse the stock pushrods from a L03 TBI which is og. roller engine. with a flat tappet cam and lifter set?
Old Mar 9, 2011 | 06:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The push rods for a stock SBC roller cam are shorter then the ones used for a flat tappet cam.
RBob.
Old Mar 9, 2011 | 04:35 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
I only post this cuz you said you got conflicting information.
It's not a matter of opinion rather a fact that you must use the longer pushrods intended for flat-tappets.
Now you have heard it from two who definitely know what's up.
I might also suggest that you avoid taking advice from those that might have said differently.
Old Mar 9, 2011 | 08:32 PM
dabird07's Avatar
Car: 92 firebird
yeah that did make it sound less confusing
and is there a recommended size i need to get???
im prettys sure not any regular size would fit
Old Mar 11, 2011 | 11:40 PM
dabird07's Avatar
Car: 92 firebird
and wat about the restrictors that go on top of the lifters do they need to be changed?
or cann i keep the stock ones?
Old Mar 12, 2011 | 01:28 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Only way to know for sure is to get a pushrod length checker.It doesnt cost much and it will get you the proper length with no guess work.
Old Mar 12, 2011 | 01:29 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
well if your getting rid of the roller lifters and installing regular flat tappet style. thier are retainers that go on the roller lifters that you do not need on the regular style. as well as the "spider" which is the metal piece that holds down the retainers for the roller lifters.
Old Mar 12, 2011 | 05:02 PM
xch3no2's Avatar
Transmission: TH400
^^What he said, the lifter retainer becomes a moot point.
Old Mar 12, 2011 | 09:23 PM
dabird07's Avatar
Car: 92 firebird
thanks guys yall are lots of help!!
imma try to do this with my motor still in the car just the front bumber off
hopefully it will work
well with my new push rods and valve springs (and possibly rocker arms)
is there any certain tools i need?
i know i ask ALOT of questions guys but i just like making sure
Old Mar 13, 2011 | 12:45 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
well if you are changing the valve springs on the car. you need a leakdown tester kit. you pump compressed air into the cylinder to hold the valves up while you change the springs. otherwise the valves will drop and most likely the motor will have to come apart. you also need the on car valve spring compressor and remover.
Old Mar 13, 2011 | 09:03 PM
dabird07's Avatar
Car: 92 firebird
ok so imm mix mATCHING my head
compcam pushrods
http://www.jegs.com/i/Comp-Cams/249/7812-16/10002/-1
summit valvesprings
http://www.summitracing.com/parts/SUM-174001/
and imm thinking about these rocker arms
either jegs
http://www.jegs.com/i/JEGS+Performan...20140/10002/-1
or
http://www.jegs.com/i/Proform/778/66914/10002/-1
opinions on if this all will work and wich rocker arms to get and is spending the extra 50 bucks on self alighning worth it
thanks!
Old Mar 13, 2011 | 11:12 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
well you have to run self aligning unless you have guideplates which you dont. id prefer not to run aluminum bodied rockers on street engines. I prefer the comp cams steel rockers but they are nearly double the price of those proforms (i cant stand proform rockers)
Old Mar 14, 2011 | 06:31 PM
dabird07's Avatar
Car: 92 firebird
. id prefer not to run aluminum bodied rockers on street engines. (i cant stand proform rockers)
wats wrong with em?????
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
