Fuel problem or something else?
Car: 1990 Camaro RS
Engine: TBI 305 V8
Axle/Gears: 10 Bolt 2.73
Hi, I have a 1990 Camaro 305 LO3 and I have a problem of some sort. Ok so when its cold it will start hesitating until it warms up a little. Next it gets **** poor gas mileage city driving or highway, I havent done the math to see what my MPG yet but I will. And third when I go above 50-55 MPH my check engine light comes on and stays on until I turn the car off then the light turns off. I have a new O2 sensor, new plugs, new cap and rotor, and no cat. What might be the problem, any help would be great!!
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: Fuel problem or something else?
Pull codes while the CEL is lit...
or
take it to someone who can/will.
or
Car: 1990 camaro RS
Engine: 305 TBI
check vacume line to EGR vavle. how many miles are on it? the TB gasket mayve gotten sucked in somewhat
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Pull codes. All you need is a paperclip and read: https://www.thirdgen.org/service-eng...ht-error-codes
Change fuel filter if you haven't done it in the last 2 years.
Car: 1990 Camaro RS
Engine: TBI 305 V8
It has almost 130,000 miles on it. The fuel filter has been changed about 1 year ago or so. I will try to get the CEL read this weekend or asap. I will write back once I get the code.
Engine: gone
Transmission: gone
Axle/Gears: gone
im going to guess you have a bad coolant temperature sensor. and the code is going to be an egr problem.
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Car: 1990 Camaro RS
Engine: TBI 305 V8
Well today I replaced the Coolant Temp Sensor and it wasnt the problem. So my next try is finding someone who can read my CEL. Hopefully asap!
Car: 1992 RS
Engine: Carbed 350
I left the link to read the codes above in post 4 - all you need is a paperclip ... really.
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
