injector problems. wtf
Old Jun 8, 2011 | 11:07 PM
Rs91sam's Avatar
Car: 91 rs 350 swap & pos 93 gmc sonoma
Engine: Lo5
Transmission: 700r4 w/ shift kit
Axle/Gears: Stock
After my swap I got my car started and drove it once. After parking it I couldnd get it to start. I figured out my fuel pump wasn't turning on. I after checking the wires and testing them with a test light and swapping relays I just rewired the whole.thing. I tried.to start.it again and now my injectors arnt coming on. Im thinking its something to do with the ecm but I don't know. Its getting frustrating. Someone help please before I get a garb haha
Old Jun 9, 2011 | 07:33 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: injector problems. wtf
did you check all the fuses. what all did you rewire. check the fuse over by the battery.
Old Jun 9, 2011 | 07:42 PM
Rs91sam's Avatar
Engine: Lo5
Axle/Gears: Stock
I checked every fuse in the fusebox and checked the one by the battery. I even replaced the one by the battery just in case. I rewired the fuel pump only. That wasn't the problem. Im at wits end.
Old Jun 9, 2011 | 09:27 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
do the injectors have a pulse? you sure your getting fuel pressure? could easily be a bad ignition control module or a problem with the VATS system. When you say you rewire it is so easy to tap or cut the wrong wire. I'd double check that.
Old Jun 9, 2011 | 09:47 PM
one92rs's Avatar
Car: SOLD!!!!!
what did you use to rewire the system. most of the fuel pump wires besides one come from orange wire from the battery. one from the oil pressure switch (sensor). but also the orange wires from the battery provide a positive to the ecm. did you cut all those out?
Old Jun 9, 2011 | 10:18 PM
Rs91sam's Avatar
Engine: Lo5
Axle/Gears: Stock
No I just ran a new hot and ground to the pump. I just remembered that when I changed chips in the ecm from a 305 to 350 chip it blew the fuse by the battery and I don't recall it running since.
83 Crossfire TA
Jan 3, 2016 01:26 PM
gta892000
Sep 16, 2015 12:37 AM
webeeZ28
Sep 14, 2015 12:00 PM
DARKmj16
Sep 9, 2015 04:07 PM
Ranbo108
Sep 9, 2015 12:20 PM
