Lots of fuel problems, running rich, flooding...
Old Jun 16, 2011 | 10:05 PM
deejaedub's Avatar
Car: 91 RS and 89 RS, 99 Tacoma TRD
Engine: 91-L03, 89-350 TBI
Transmission: 91-700r4, 89-T5
I put a new 350 in my 89 TBI. I have a few problems. When I turn the key to on, the fuel pump primes but doesnt stop after the 2 seconds. When I crank the engine the injectors both spray but flood the engine. The fuel pump is fairly new, so I don't think it is that. Any ideas on why?
Old Jun 17, 2011 | 03:14 AM
1992COUPE's Avatar
Car: 92 RS 25TH ANNIVERSARY All original
Transmission: T5 WORLDCLASS
Axle/Gears: 3.08 OPEN
Re: Lots of fuel problems, running rich, flooding...
Sounds like the injectors are open.Sure all the wires are hooked up? check the connectors at the injectors for power.
Old Jun 17, 2011 | 06:15 AM
camaroinoh's Avatar
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
If injectors check out my next move would be the regulator check fuel pressure with key on and also at cranking
Old Jun 17, 2011 | 06:49 AM
ex-x-fire's Avatar
Are you saying the f. pump runs continually even if the engine isn't running?
Yeah, check the uel pressure, but also check the ecm grounds on the back of the heads. Do a resistence test of the coolant temp sensor (google for the temp/ohms values) as this can make it run rich. Also blow through the return fuel line w/ the gas cap off. It should be unrestricted.
Old Jun 28, 2011 | 07:05 PM
deejaedub's Avatar
Ok, so miraculously the fuel pump is now operating normally. Hmm... My only problem now is that as the fuel is being injected the car wont start. It seems lean instead. It will start with starter fluid, and I can keep it running by fluttering the throttle. But it wont idle and as soon as I let off the throttle it will die. The fuel pump is supposedly new, I am considering the fuel filter. I am going to check fuel pressure one of these days when I can afford to by a tester. Any other ideas on what might be wrong?
Old Jun 29, 2011 | 01:45 PM
Ronny's Avatar
Why buy a tester. Borrow at auto zone.
Old Jun 29, 2011 | 09:12 PM
92SuperCoupe's Avatar
I am having a very similar problem with my 305 tbi. It gets better when I take off the vacuum line from the front of the throttle body. Does yours do that? Does anyone know what causes this?
Old Jun 30, 2011 | 09:28 AM
Ronny's Avatar
ECU hold any codes? I would run the test to see what is there. I presume no CE light "on".
Old Jun 30, 2011 | 10:00 AM
I'm not sure about the OP, but my ses comes on after a while. Advance said they can't read codes on a 92 thou. Also my exhaust appears to be cut off, would this affect anything?
Old Jun 30, 2011 | 10:23 AM
Ronny's Avatar
You need to read codes by jumping ALDL and count the blinks. There are OBD 1 code readers. Advance apparently does not have one.
Old Jun 30, 2011 | 01:04 PM
Would you happen to know how to do this? Sorry I am new to working on anything other than a carb! I'm deff converting over to one soon...don't really like FI!!
Old Jun 30, 2011 | 01:26 PM
Ronny's Avatar
You need to do a search or maybe it is in stickies. My ECU does not require a jumper. I believe on ALDL there is a port that you jumper the ALDL connector to ground. Dont do just search and confirm. First CE blinks are 3 blinks -pause- followed by the error code blinks. Like 3 blinks pause 5 blinks pause and 3 blinks. the 5 blink means a specific code. You need to locate chart and determine the sequence of blinks for each code. If all 3 blinks then no code present. Maybe a video U tube???
Old Jul 2, 2011 | 06:06 PM
deejaedub's Avatar
I am pulling code 24. I checked fuel pressure, and at cranking I get about 15 psi.
MustangBeater20
Oct 29, 2022 09:20 PM
jhawkeye
May 25, 2022 06:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
squiggy2
Aug 9, 2015 09:30 PM
