Need Engine ID Help
Old Jul 13, 2011 | 02:22 PM
rfcomp's Avatar
Car: 1990 Camaro RS
Need Engine ID Help
I have a 1990 Camaro RS and am going to do a rebuild, I just want to be sure what engine I have. The Numbers I found are V0907BLD. Can anyone ID this??
Any help would be appreciated.
Old Jul 13, 2011 | 07:23 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Need Engine ID Help
Those numbers are not correct - not engine ID numbers.
If your car is stock and a 8 cylinder TBI car, then it's a 305 5.0 litre LO3 TBI engine. The engine ID numbers are on the driver side, rear of the block, at the back of the driver head ... almost impossible to see with the motor in the car - but it's there. You'll most likely see the "5.0" stamped in the block as well as a 6-8 digit number (no letters).
Old Jul 14, 2011 | 08:28 AM
rfcomp's Avatar
Car: 1990 Camaro RS
Thanks I'll keep looking.
Old Jul 14, 2011 | 11:03 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
yup its right where newbie said. between the cylinder head and where the transmission bellhousing meet up. should be able to see a big ol 5.0L stamped there
Old Jul 14, 2011 | 08:27 PM
1gary's Avatar
Those "V" numbers is a date code and location of the build.But not which one.
The guys have told you about casting number which is on the pad above the bellhousing.Some carb cleaner and a mirror might help you see what they are.
Here is a link that could help:
http://web.archive.org/web/200805180...ww.mortec.com/
You want to bookmark it.The site isn't around any longer.
Old Jul 15, 2011 | 06:06 AM
rfcomp's Avatar
Car: 1990 Camaro RS
I found the casting number finally and I used the link to the website provided (Thanks for that.) but The number is not listed there. The number is 14093627, I'll keep looking to find this somewhere.
Old Jul 15, 2011 | 07:16 AM
rfcomp's Avatar
Car: 1990 Camaro RS
Never mind I found it in a sticky in the engine swap section.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
