Timing retards after i reconnect wire
Old Jul 18, 2011 | 09:50 AM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
With the wire disconnected I set it to 6 degrees advanced and then when i plug it back in the timing gets retarded to like 6 or 8degrees retarded?
I can set the timing with the wire plugged in to about 6 and itll jump around between 5-7 advanced at idle.
The engine is running rich at the moment, is it retarding the timing trying to burn more fuel or what?
Should I just set the base timing with the wire plugged in so it stays at around 6 advance or do it with the wire unplugged and let it retard the timing so much?
This is on a mild 350tbi
Old Jul 18, 2011 | 12:29 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Timing retards after i reconnect wire
Strange, normally when plugging the EST by-pass connector, timing should be around 16-24° depending on the idle state SA and/or base timing in the tune.
BTW how did the boosted 305 turn out?
Old Jul 18, 2011 | 01:11 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Either the ignition module is bad, the pickup coil is bad, or the pickup coil wires to the ICM are reversed.
RBob.
Old Jul 18, 2011 | 07:28 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Ended up backing out of the boosted 305tbi in favor of a 350.
I had a vortech on my camaro though with a 350tpi, constantly had issues and it poped the head gaskets cause I was always getting knock, i ended up just selling all my boost stuff and buying my 350tbi engine.
RBob, the distributor is a fairly new one from the auto parts store that I used before without issue and all i did was change my intake gaskets, put new spark plug wires on and put the distributor back in and did the timing now its retarding. Before it would hold steady around 6adv with or without the wire plugged in. The headers are also glowing red hot.
Old Jul 18, 2011 | 08:53 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
glowing hot headers its running too rich it seems and the burn is happening with the exhaust valve open. so maybe your timing is actually off? Im just throwing something out there.
Old Jul 18, 2011 | 09:02 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Could you have an ESC(knock sensor) fault that's commanding full retard?
Old Jul 19, 2011 | 01:06 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Womp womp, I feel dumb
I had it set at 6 retarded, instead of 6 advanced.
But I reset it where it needs to be, and the timing jumps to probably 20ish advanced with the wire plugged in and the exhaust isent glowing any more.
So thanks for the help guys, sorry if I made anyone waste too much time trying to help me.
Now I just have to wait for the dyno shop to get there dyno fixed
Old Jul 20, 2011 | 05:22 PM
thomas1976's Avatar
Car: 91 Trans am
Well at lest you have some nice experience , hope it turns out better with the 350 tbi.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
ZsTransAm
Aug 11, 2015 07:30 PM
apie2546
Aug 8, 2015 07:12 AM
