LT1 cam in TBI 350? Good idea?
Old Jul 26, 2011 | 04:20 AM
ChevyK0051's Avatar
Car: 1995 Chevy K1500 extended cab white
Engine: 5.7L TBI V8
Transmission: 4l60E
Axle/Gears: stock (3.73?)
I've just got some LT1 roller lifters and was wondering how I would go about putting the rollers to good use in my '87 TBI block? casting number is 10054727. I need the vortec's spider tray(drill and tap the three holes for it), LT1 camshaft, vortec or LT1 timing set, and do I need vortec or LT1 pushrods too? Thoughts? Maybe the vortec's cam instead?
Thanks!
Old Jul 26, 2011 | 07:29 AM
1gary's Avatar
Re: LT1 cam in TBI 350? Good idea?
I have some experience with a TBI and this GM cam number which worked very well.
#14097295
Old Jul 26, 2011 | 10:44 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I cannt see the three pedastals you'd need to drill and tap in that picture. plus you'd also need a cam thrust plate that goes on the front of the camshaft under the timing cover with a roller setup which I dont know if the block is drilled for those either...???
Old Jul 26, 2011 | 12:07 PM
ChevyK0051's Avatar
Engine: 5.7L TBI V8
Transmission: 4l60E
Hmm undercover, I googled a picture of a vortec block and I saw the pedestals you mentioned. I didn't know there were pedestals..dang. hmm anyone know of some retro roller kits that aren't $400?
Old Jul 26, 2011 | 08:29 PM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
You could buy another engine for the price of retrofit lifters. Buy a used vortec engine. You could sell the heads and come out ahead. You would then not have to drill/tap anything. You would have all the parts you need as well.
Old Aug 4, 2011 | 02:57 PM
woody80z28's Avatar
Car: 80 Camaro Z28
Engine: ~400hp Vortec 355ci
Transmission: T56 6-speed
Axle/Gears: 4.10 Moser 8.5" 10-bolt
I just finished up a L05 Vortec LT1 cam build. Vortec/LT1/TPI lifters, dogbones, spider, pushrods, etc should all be the same. I used the LT1 cam because it has a little more lift & duration than the Vortec cam. And I used a GMPP roller timing set that was cheap...like $50 from Summit and came with both size thrust plates.
I agree you should buy a roller-ready block to do it though. If you decide to stay flat tappet Comp does make some XE cams that have ramps rates similar to a factory roller.
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
camaro71633
Sep 1, 2015 10:24 AM
