TBI Idle and running issues...needs help!!!
Old Jul 28, 2011 | 06:33 PM
86FLIROC's Avatar
I recently replaced the intake gasket on my sons 92 tbi.
I have a feeling the gasket shifted or is otherwise leaking.
These are the issues...
1- slow to start
2- when it starts, races at about 1300 rpm or so.
3- coolant gurgling
4- cylinder 5 and 7 no firing, mostly 7.
5- attempt to drive, it stalls...runs like crap.
6- smells like antifreeze out tailpipe.
Neighbor came down, looked at it, says head gasket. Was not a issue until this was all fixed.
Shawn
UPDATE!!!
I changed the intake gasket again, as well as the TBI gasket. It started up and it idled normally for about 45 seconds, then took off again in high rpm, around 1700 rpm or so, then came down to around 1300, where its staying.
Just for curiosity, I unplugged the tps sensor, no change, but the engine continued to run, and accelerated fine with no hesitation with the tps unplugged. I wasn't expecting it to do that, but perhaps that's how its set up.
I keep thinking about the IAC valve...seems to be hissing rather loudly from the tbi unit, and if i spray carb cleaner in the small port for the IAC on the top of the tbi unit, it just about kills the engine. I have also sprayed around the intake area and all vac lines, and there's no changes.
One thing, the coolant gurgling and the smell of antifreeze out the pipe are now gone, but the rest of the symptoms in post 1 still remain.
I am totally stumped...Anyone have any ideas at all?
Shawn
Old Jul 29, 2011 | 04:36 PM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
Re: TBI Idle and running issues...needs help!!!
1- slow to start
3- coolant gurgling
Shawn
UPDATE!!!
Shawn
The hissing is a vacuum leak. Gotta figure out where it is coming from. Will cause the high idle and other problems
MustangBeater20
Oct 29, 2022 09:20 PM
camaro71633
Sep 1, 2015 10:24 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
squiggy2
Aug 9, 2015 09:30 PM
