Have to pump gas to start when my car is cold?????
Old Aug 1, 2011 | 06:27 PM
Sparkko's Avatar
Car: 1988 Firebird Formula
Engine: 5.0L 305 TBI
Its weird.
When I try to cold start my car, I have to pump the gas, or else it won't start?
I thought with TBI fuel injection you shouldn't have to pump the gas to start it?
Old Aug 1, 2011 | 08:35 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Have to pump gas to start when my car is cold?????
I doubt pumping it is making any difference. Check your fuel pump relay.
If the fuel pump relay isn't working, the pump won't "prime" for 2 seconds before startup. Unless primed, the injectors have no fuel. What's happening, is that the OIl Pressure Sending Unit (OPSU) is taking over as a backup circuit to operate the fuel pump - but this takes a few seconds of cranking ... and this is happening while you are "pumping".
Old Aug 1, 2011 | 09:00 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I pretty much agree with what camaronewbie said.
Also another thing to note is that a bad Coolant temp. sensor will cause a weird cold no start condition. But I think your's is more what newbie said.
Old Aug 2, 2011 | 02:54 PM
Car: 1992 RS
Engine: Carbed 350
Originally Posted by UnderCover89TBI
Also another thing to note is that a bad Coolant temp. sensor will cause a weird cold no start condition. .
You know - I never think about CTS, because neither my 1990 or my 1992 car had them - and so I have no clue what a bad CTS can do for a car (besides radiator fan issues). I'm always confused when anyone mentions TBI car and CTS together, since I've never personally seen a TBI car with a CTS.
So glad you chimed in - maybe someday I'll remember that some TBI cars did have a CTS (but don't hold your breath).
Old Aug 2, 2011 | 05:04 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah I feel ya. And on my car the CTS has nothing to do with the radiator fan. haha. it is located on the intake manifold, by the thermostat housing. sometimes it isnt even the sensor going bad it's a bad connector. they used to sell the connector with the sensor but have since stopped from what I have seen. It would not suprise me if that was this guy's problem.
Old Aug 4, 2011 | 08:39 AM
Sparkko's Avatar
It has everything to do with pumping.
If you don't pump it, it won't start at all.
Old Aug 4, 2011 | 08:40 AM
Sparkko's Avatar
My Cooling temp sensor isn't funtioning properly.
Old Aug 4, 2011 | 10:19 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Its weird because pumping should have no implications before key on. Now I can see when your trying to start and you pump it, the TPS sensor reads different and says more fuel. But not with key off. Did you change that sensor yet?
Old Aug 4, 2011 | 11:36 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Rather than pumping, which really doesn't do anything but move stuff (no fuel gets shot in like a carburetor does), just hold the pedal at 1/2 the travel. Try it once at halfway and once at full throttle.
Apparently, your TPS is not telling the ECM what it wants to know in order to give you enough fuel to start. You are running lean at idle probably after you get it started as well.
You need to check your fuel pressure. You will need an adapter to do this. I bought mine from eBay and it allows me to use a regular fuel pressure gauge like the TPI and V6 guys use.
1. Your fuel pump is probably shot. They are junk brand new, and replacements are not any better. Go to the parts store and buy the fuel pump for the 89 Turbo Trans Am and use that one. Its better than the TPI pump, too. It was a good enough pump that GM used it up to the late 90's in pickup trucks with the vin code R Vortec engines.
2. You may have a clogged fuel filter, change this first.
I just went through something similar with my 89 'bird before I left. One new vortec pump later, it runs like a million bucks.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
