newbie needs help 305 tbi stalling when warm
Old Aug 2, 2011 | 04:56 PM
92maro-rs's Avatar
I need some help bought my 92 Camaro rs 305 tbi about six months ago everything was fine until a month ago my water pump went ou I replaced it right away ever since everytime I drive it when the temp gets to 200-220 it stalls at stop signs red lights starts up right away but hesitates for about 5 seconds then will catch itself and drive need all the help I can get thanks .
Old Aug 2, 2011 | 06:58 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: newbie needs help 305 tbi stalling when warm
Maybe a Igntion Control Module - it's located inside the distributor under the rotor button - just remove dist cap (mark wires on cap if you have to remove them), pull out rotor button, and you'll see it under there. They can be tested at most auto parts stores, but a test does little good most of the time. They stop working when they get hot (like any electrical part), and testing it doesn't make it hot. If you replace, or remove the old one and reinstall, make sure you use dielectric grease on the metal plate before reinstall - this grease keeps the plate from rusting, allows electrical contact, and the rust build-up creates electrical resistance thus increases heat thus makes unit go bad.
There could be other issues at play, but that's the first thing that comes to mind.
Old Aug 2, 2011 | 07:23 PM
92maro-rs's Avatar
Thanks I will try that next and well see what happens
Old Aug 5, 2011 | 11:49 PM
chevy77's Avatar
Car: 1977 nova rally
Engine: 89 tpi 305
i am having a somewhat similar issue with my 89 tpi 305 it stalls and hesitates so bad i can barely drive above idle im thinking maybe fuel problem but im having trouble locating the problem
Old Aug 6, 2011 | 12:22 AM
1badride's Avatar
Car: 1988 RS Camaro
Engine: 305 TBI
Axle/Gears: Stock
Originally Posted by camaronewbie
Maybe a Igntion Control Module - They can be tested at most auto parts stores, but a test does little good most of the time. They stop working when they get hot (like any electrical part), and testing it doesn't make it hot.
Unless your Parts Guy runs it through several consecutive tests to get it hot.
Old Aug 23, 2011 | 09:41 AM
92maro-rs's Avatar
I changed the icm yesterday and still the same problems what else can it be
Old Aug 23, 2011 | 06:16 PM
ex-x-fire's Avatar
Did you get all the air out of the cooling system?
Old Aug 23, 2011 | 06:32 PM
OldMan89's Avatar
Car: 89 Firebird
Engine: 305 SBC
Not sure I would call this a "fix", but you could install a lower temp thermostat. I run a 190 without issues in my 305 TBI. Assuming it only happens after 200 deg.
Old Aug 23, 2011 | 07:16 PM
Ricks87iroc's Avatar
Car: 88 camaro, 87 iroc
Engine: 305 tbi, 305 tpi
Transmission: manual\auto
I had a similar problem on my 88 camaro. It would get to about 200-220 and stall out, but if i let it cool down for 10 to 15 min. it would fire right back up. I changed the pickup coil, never had a problem since.
Old Aug 24, 2011 | 10:45 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
very possible. OP may want to change entire distributor. Take module back and apply towards new distributor. I hate throwing parts at cars. IMO you may want to take to an auto repair facility and have them diagnose it.
Old Aug 24, 2011 | 11:30 AM
92maro-rs's Avatar
Taking it to get diagnosed will be my next step if the pick up coil doesn't help. thanks for all your help guys
Glowsock
Jul 24, 2025 03:15 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Dwayne614
Sep 28, 2015 08:33 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
