Firebird formula 89 dies when put into gear.
Old Aug 25, 2011 | 07:46 PM
Gadp74's Avatar
Car: Firebird Formula 1989
Engine: 305, TBI
Hi, I have a problem and maybe one of the seniors can help me....My car starts without problem when I remove the air cleaner assembly, I put it in drive and I can drive the car but when I install the air cleaner assembly and I put it in drive it dies.
I installed the air cleaner assembly and try to start it but nothing happens.
I appreciate any help.
Old Aug 28, 2011 | 04:38 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Re: Firebird formula 89 dies when put into gear.
If you're properly hooking everything up with the air cleaner assembly, there should be a vacuum hose right up near there. The removal of the vacuum hose when you take the air cleaner assembly off could be what is allowing the engine to run and when you reattach the vacuum hose, it drops the idle to a speed that dies when you put the car in gear.
If that's the case then there's another problem to address, which is independent of the air cleaner assembly.
As far as the air cleaner assembly is concerned, the only other possibility I can think of is the Ambient air temperature sensor or something that's located in the air cleaner, however, I don't think a faulty sensor could cause the engine to die.
Check that vacuum hose that I mentioned.
Old Aug 29, 2011 | 05:25 PM
Gadp74's Avatar
Engine: 305, TBI
Thanks for your reply, I am going to check all my connections again, about the little hose going to the tbi I think I am going to replace because its soft and maybe is collapsing with vacuum.
Old Sep 3, 2011 | 05:13 PM
Gadp74's Avatar
Engine: 305, TBI
problem fixed, the timing was way off, now I have to adjust the valves
eightsixseven
Dec 16, 2024 01:50 PM
xkingcodex
Feb 12, 2020 07:43 PM
jklein337
Sep 19, 2018 06:23 PM
theshackle
Mar 5, 2017 06:37 PM
