Dissconnected vacuum hose.
Old Aug 30, 2011 | 07:34 PM
Sparkko's Avatar
Car: 1988 Firebird Formula
Engine: 5.0L 305 TBI
One of my vacuum hoses are disconnected and all of the hoses going into the TBI are connected. It looks like the hose is coming from inside the firewall, and is less than a Centimeter thick. My A/C is stuck on Defrost, and I think the hose might be in relation with that problem. Any ideas on where that hose needs to be connected?
Old Aug 30, 2011 | 07:51 PM
Sparkko's Avatar
Re: Dissconnected vacuum hose.
whoops forgot the pics.
Attached Thumbnails Dissconnected vacuum hose.-img_0041-large-.jpg   Dissconnected vacuum hose.-img_0042-large-.jpg
Old Aug 30, 2011 | 09:40 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea thhere a plastic valve that has 2 one inch hose going to it it connects there
Old Aug 31, 2011 | 05:02 PM
Sparkko's Avatar
I couldn't find a valve with an empty slot, post pics.
Like I said it DOESN'T go to the TBI.
Old Aug 31, 2011 | 08:51 PM
torque_is_good's Avatar
is air only blowing from your defroster? In other words, it does not move from defroster to a/c vents when you move the lever?
Old Aug 31, 2011 | 09:00 PM
ex-x-fire's Avatar
There should be a vacuum reservoir somewhere.
You can hook the line to any vacuum source to see if the postions change at the heater controls.
Old Sep 1, 2011 | 03:56 PM
Sparkko's Avatar
that is correct. But it does make a strange clicking noise.
Old Sep 1, 2011 | 04:02 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Looks like the vacuum line that goes to the "top" (in the pic) of the heater bypass valve, looks broken too.
Old Sep 1, 2011 | 08:20 PM
well there you go. By asking you that question it confirmed my hunch. Follow your heater core hoses to a plastic housing that looks like a space station. That vacuum line plugs in there and it will fix your issue about air only comes out the defroster
Old Sep 3, 2011 | 01:26 AM
jreyes916's Avatar
Car: 89 camaro
Engine: 5.7 from an 89 blazer
so i also have this problem it only stays on defrost but i see no unplugged hoses on the picture you have shown so can any one help?
Old Sep 3, 2011 | 05:14 PM
Sparkko's Avatar
Bought the bypass valve fixed the leak, and my a/c is still stuck on defrost...
Need more help.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
