Wacky MAP values
Old Sep 5, 2011 | 11:13 AM
TXBowTie40's Avatar
Wacky MAP values
This one has me pulling my hair out..........
Start up and idling, it shows MAP of 38.93 kPa, going down the road it gives me similiar readings during a steady state light throttle cruise.
But I noticed the other day that when I start to feed it more throttle, the MAP values will go up to 50-60ish, then start to FALL.......then in turn affects my fuel and spark maps, and as a result the truck runs like crap.
I replaced the MAP sensor not too long ago, so I'm trying to chase down what could cause the problem.
I looked under the truck and the catalytic converter is still there......might it be stopped up and causing a back pressure issue that is showing up as wacked out MAP readings?
Old Sep 5, 2011 | 04:45 PM
ex-x-fire's Avatar
Re: Wacky MAP values
I'd hook a vacuum gauge to the line going to the map, see how smooth the needle is moving. Should have 18" or more at idle w/ a smooth needle.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
aaron7
Sep 30, 2015 09:15 AM
ULTM8Z
Sep 16, 2015 09:15 AM
