14 mpg :(
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
14 mpg :(
In getting about 14 mpg right now, but a few weeks ago I was getting 17-18, and I haven't been driving any differently than normal, I have a 305 tbi which is all stock except and open element and aftermarket muffler with 2.5" tailpipes, so neither of those should affect mpg, especially not in a bad way, so do you think there's something wrong? Or was it just thirstier for gas this week?
Car: '91 Camaro RS
Engine: Carb'd 383
Re: 14 mpg :(
Yes the gas cap is always on tight because I know that just loosening the cap releases the fuel pressure through the whole tbi system, and yes, I work at a gas station so I always fill up before work when I need to
Car: '91 Camaro RS
Engine: Carb'd 383
Re: 14 mpg :(
I'm going to do that, I've been planning on a full tune up in the spring, hopefully that's all it will need, I don't think it's bad enough to say it could be the o2 sensor
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 14 mpg :(
ok well my gas tank had a crack in it for years and it didnt affect my gas mileage so that would be the same as the gas cap not sealing. so that is not your problem.
Either your in need of a tuneup. your not at a full misfire yet but the engine is just going thru more fuel.
your oxygen sensor is bad, or your Coolant temp sensor is bad. telling the engine it needs more fuel so your getting overfueled.
your catalytic converter is plugged up, makign exhaust gases back up into the engine, heating up the combustion chamber and burning more fuel.
Car: '91 Camaro RS
Engine: Carb'd 383
Re: 14 mpg :(
Any easy way to test an o2 sensor? And would any of the cause me to fail emissions? Because I just passed that a few weeks ago
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 14 mpg :(
best way to test o2 sensor is to change it. its only 20 bucks from your local autoparts store. althought i would spring for the ac delco 1 wire which is a little bit more
Car: '91 Camaro RS
Engine: Carb'd 383
Re: 14 mpg :(
I was going to change that when I did a tune up because they aren't too expensive, it might have to be before spring if this gets any worse, I feel like the problem would be worse if the o2 sensor was bad, but I don't know much haha
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 14 mpg :(
Is the car running cooler? If the thermostat is stuck open you could be running too cold, causing the engine to stay in open loop, therefore using more fuel.
Same basic deffinition if your coolant temp. sensor is not working properly
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Re: 14 mpg :(
I'd suggest using seafoam to treat the engine and gas tank. As far IMPROOVING MPG, better exhaust and spark plugs are a good Idea.
Car: 1990 camaro RS
Engine: 305 TBI
Car: 1992 Camaro RS
Re: 14 mpg :(
Correct. But it certainly wont do any harm.
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: 14 mpg :(
Car: '91 Camaro RS
Engine: Carb'd 383
Re: 14 mpg :(
Well I know there aren't any leaks from the muffler back, and I plan on spark plugs and full tune up next spring, hopefully there's nothing wrong because my budget is tight and time is limited due to school and work
Car: 1992 Camaro RS
Re: 14 mpg :(
Very odd. These cars get great MPG. Not fuel eficiant, just restrictive. I don't know why you would experiance such a drop.
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 14 mpg :(
It could be anything. you could have sprung a vacuum leak anywhere so small. its really hard to say. Are you sure your getting into OD and lockup? a lot of variables here..
Re: 14 mpg :(
Check for vacuum leaks, esp the hose going to the map sensor. Put a vacuum gauge on it, tee'd in the map hose. It should be 18"or more at idle w/ a smooth needle. If it is low check for leaks, check the ignition timing too. Slow timing or no advance will cause a low vacuum condition which will make it run rich.
If you haven't put a t-stat in it in a while, go ahead & put a 195* stat in it. Those are the best for mpg.
Check the ecm grounds, bad grounds will make 'em run funny. They should be on the back of the heads or near the t-stat housing.
Re: 14 mpg :(
check for vacuum leaks first. look for lines that may be cracked or have rotted. mine was the coolant temp sensor for the ecm. also check the vacuum on the engine. borrow a timing light and check the injectors pattern. if there is no vacuum leak and the vacuum shows a good smooth readint then it will either be the map of the coolant temp sensor. the coolant temp sensor is the cheapest.
Car: '91 Camaro RS
Engine: Carb'd 383
Re: 14 mpg :(
What's lock up? And will driving to school with three other people in my car cause this big of a drop? It's only a mile away
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 14 mpg :(
I agree. If your going 1 mile with a fully loaded car your going to lose gas mileage. Right now I am averaging 19 mpg highway and around 13 in town or so.
Car: '91 Camaro RS
Engine: Carb'd 383
Re: 14 mpg :(
Well I've only had short trips in my car, 3 miles to work, 4 miles to my girlfriends, and 1 mile to school, and I dont really go anywhere else, but my mpg has never been like this even tho I only drive short trips
Car: 1990 camaro RS
Engine: 305 TBI
Car: 1988 Camaro
Engine: 350 4bbl
Re: 14 mpg :(
yeah, thats why when you have seafoam you do as the instuctions say not to lol! Ifyou have a carbed setup, if you really want to clean the engine out, POUR IT DOWN THE CARB!!! I did it with my 1990 silverado, white smoke all over the o'reilley parking lot...
it sigificantly helped! mpg's didnt get any better, but it sure ran much smoother. I drove the **** out of that truck, and wished I kept the TBI 350. It had all the emissions delete stuff, (which supposedly means it came from canada) Good luck my combined mpg in my 88 RS 305tbi-T5 is 15mpg... 14 isnt bad. I got 8-10mpg out of the 350TBI in my truck
it sigificantly helped! mpg's didnt get any better, but it sure ran much smoother. I drove the **** out of that truck, and wished I kept the TBI 350. It had all the emissions delete stuff, (which supposedly means it came from canada) Good luck my combined mpg in my 88 RS 305tbi-T5 is 15mpg... 14 isnt bad. I got 8-10mpg out of the 350TBI in my truck Re: 14 mpg :(
have put 404 miles on my car this month. after changing the coolant temp sensor and bleeding the cooling system one more time i got mine doing well. went from 14mpg back up to 21 to 24 depending on my mood. the first 200 mile trip was 21mpg doing 80 all the way. this time i only rolled the windows down about half way and ran 70 the whole way. 24.5mpg. might give it a try. i also only use ac delco sensors.
Car: '91 Camaro RS
Engine: Carb'd 383
Re: 14 mpg :(
About 2 months ago I needed a new radiator so I got new hoses too and flushed the system and put new coolant in, so I dont think doing that again will help, I'll probably get some new sensors when I do a tune up in spring though
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: 14 mpg :(
dang i been having the same problem with my ford ranger, its got the 2.3 and im down to 15mpg, and every sensor is new, new distb/module/coil/wires/plugs no cat egr blocked off, fuel pressure is good, compression is good..... im down to the fuel injectors on it but its stupid that i get 18-21 in my maro and only 15 in the ranger..... i got to get that thing fixed
Car: '91 Camaro RS
Engine: Carb'd 383
Re: 14 mpg :(
That's because it's a ford haha but there's deffinetly something wrong if you're getting 15 mpg
Car: 1992 Camaro RS
Re: 14 mpg :(
Maybe your not burning fuel well. Are you running rich or having to give it more gas to get up to speed?
Re: 14 mpg :(
im running lean according to the plugs and the fact there is no trace of any black "soot" in the exhaust ...... i was hopeing that me and the O.P.may have the same problem, but it looks like he has some sensors and all to try and maybe even a tune up, and i have done all of that ...... got to love it
Re: 14 mpg :(
suppose this would all be relivent to me with a 87 firebird 305 w/4bbl quadrajet? Gas mileage seems way worse than it should, i also have black soot coming from exhaust, running to rich? First f-body, and new at working on cars, so its a learning process for me
Re: 14 mpg :(
https://www.thirdgen.org/forums/tech-general-engine/
Car: '91 Camaro RS
Engine: Carb'd 383
Re: 14 mpg :(
Definitely running rich and just wondering but why do you have a 4bbl on a 305?
And 89RS mine might not be sensors, it might be the short trips to school with an extra 450 pounds in the car, plus all my tools for work
Car: 1992 Camaro RS
Re: 14 mpg :(
But seriously, what do you have in your car?
Car: 1992 Camaro RS
Car: 1984 T/A
Engine: LQ4
Re: 14 mpg :(
Between the last 5 fill-ups ive dropped from 18-15 and i only do highway miles for the most part.
