305 to 383 swap
Old Sep 12, 2011 | 07:32 PM
t-roy383's Avatar
305 to 383 swap
i recently replaced a 305 for a 383 in a 91 rs. i used the 305 heads, intake, distributer, and 350 injectors, it has a .495 lift cam. i had a custom chip made, but i am still having some issues. the car idles good til in gear, and it has a dead spot when acceleratoring til it warms up, the plugs are carbon fouled. any suggestions?
Old Sep 12, 2011 | 08:31 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: 305 to 383 swap
Sounds like a bad tune to me. Fouled plugs means it's pig rich. A dead spot can also be a result of parts of some of the cells in various tables being way off. My corvette did that... At certain conditions the car would stumble, and my scan tool revealed a momentary lean condition. Cranking the fuel pressure eliminated that issue, but obviously caused other problems.
Old Sep 13, 2011 | 04:07 PM
t-roy383's Avatar
Re: 305 to 383 swap
thanks for the response, ive ordered an aldl cable and program to connect with my laptop, hopefully i can see the problem. if i up the fuel pressure to take care of the dead spot, i will still be running to rich, right. what do i do about that? thanks
Old Sep 13, 2011 | 05:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I assume you still have TBI on the engine, so if that's the case, I'll move this to that forum where you're more likely to get useful information.
Old Sep 13, 2011 | 06:03 PM
t-roy383's Avatar
Re: 305 to 383 swap
ok sounds good to me, thanks
Old Sep 13, 2011 | 06:11 PM
t-roy383's Avatar
Re: 305 to 383 swap
just let me know which one it is, thanks
Old Sep 18, 2011 | 09:07 AM
1Broke_camaro's Avatar
Car: 1992 Chevy Camaro
Engine: 350 TBi in the working
Transmission: 700R4 :(
Re: 305 to 383 swap
your running a 383 with stock 305 heads??? rip those damn heads off and get some decent heads on it. your suffocating the engine lol
Old Sep 18, 2011 | 04:35 PM
t-roy383's Avatar
Re: 305 to 383 swap
would a set of stock 350 heads be better? im on a tight budget
Orr89RocZ
Apr 25, 2016 08:28 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
st.evel07
Aug 13, 2015 06:15 PM
