Front Acc help
Old Sep 13, 2011 | 02:18 PM
1Broke_camaro's Avatar
Car: 1992 Chevy Camaro
Engine: 350 TBi in the working
Transmission: 700R4 :(
Front Acc help
i pulled my smog pump and A/C off, how have you guys ran your belt up front? since the alt and p/s pump are both on the driver side. did you run it old school with a v-belt? or how did you config. your front setup? any pics would be amazing to please.
Old Sep 13, 2011 | 03:19 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Front Acc help
if you've got a serpentine setup (and 92 does), you can't run a vbelt because your water pump is reverse rotation. if you got an older pump (87 or older iirc), you should be ok, but you'll have to get creative with pulleys since all of them will need to be changed.
Old Sep 13, 2011 | 08:09 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Front Acc help
Not sure you can delete the A/C and the smog pump without at least one delete pulley in place for one of them - thus why alot of folks but the A/C delete pulley and route the serp belt like www.thirdgen.org/serpentine
You can switch to a V belt setup, but this requires that you swap water pump AND p/s pump AND alternator, as well as the crank pulley AND all new brackets - you need accessories from a pre-1988 car. If even considering this noption, don't waste your time on any aftermarket p/s pump bracket except the March or the Billet Specialties brands - NOTHING else worked when I did this. Alternator brackets are easy, most any one of the aftermarkets fit well.
Old Sep 13, 2011 | 08:43 PM
Re: Front Acc help
yea idk why im a dumbass and didnt think just throw a a/c delete pulley on there. this thread is completely stupid on my part. im soooo fing caught up in this wiring that for some reason i completely OVER thought the rest of the problems with the car. im sorry guys, but thanks for helping me get my head out of my *** lol
Old Sep 13, 2011 | 09:51 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Front Acc help
there is no such thing as a stupid question or idea as long as you are open to suggestions. period. now when i did my a/c and smog pump delete i ordered the a/c delete pulley. now this is going to hurt but oh well. i made a bracket at work for the smog pump delete and it has a __ford idler pulley on it___to keep the belt from bouncing. but there have been a number of people that have run the belt the rerouted way without problems.
Old Sep 13, 2011 | 10:08 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Front Acc help
Yes you have to do a a/c delete pulley..well that is cheapest option. and I did not install a fixed idler for my missing smog pump and I have had no problems
Old Sep 13, 2011 | 10:10 PM
Re: Front Acc help
yea ill prolly be a cheap *** and just run the ac delete pulley and if it starts wobbling and **** ill throw a pulley down there, but its only a stock 305 with headers so im not worried about spinning that big monster V8 out to 6k rpms and throwing belts off like my old 468 did lol
customblackbird
Aug 15, 2021 10:16 PM
TheJoeY88
Dec 31, 2016 07:30 PM
lee01
Apr 9, 2016 01:56 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
stalkier
Aug 21, 2015 01:54 AM
