A/C DELETE QUESTION...
Old Sep 16, 2011 | 12:29 PM
Sttn89's Avatar
Car: 89 caprice
Engine: 350 650 dp on roids
Transmission: 700r
I wanna delete the a/c in my car but I wanna retain the heat.Is this possible?I can deal with summer and no air but I cant do no heat in the winter.
Old Sep 16, 2011 | 12:40 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Re: A/C DELETE QUESTION...
Yes it is possible.
Old Sep 16, 2011 | 01:15 PM
Sttn89's Avatar
Car: 89 caprice
Transmission: 700r
How?
Old Sep 16, 2011 | 02:35 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
well you can just remove your a/c and retain the stock box and work fine, or you can buy a heater only box
Old Sep 16, 2011 | 04:22 PM
Sttn89's Avatar
Car: 89 caprice
Transmission: 700r
Im confused.Do u mean buy another heater box?Y would i have to do that?Wat do I keep nd wat do I delete.
Old Sep 16, 2011 | 04:53 PM
Car: 1990 Camaro RS
Yours will work or you can by the heater box without provisions for AC.
Old Sep 16, 2011 | 05:03 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
if you want a cleaner look you change the whole box out. if your ok with the a/c system somewhat being there but u can remove the compressor, drier, hoses, condenser etc for an almost complete removal.
Old Sep 16, 2011 | 08:49 PM
Sttn89's Avatar
Car: 89 caprice
Transmission: 700r
cant i fab up something to cover that void instead of buying another box?
Old Sep 16, 2011 | 08:54 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
If you keep your box now and delete the a/c, it will leave you with a hole in the box where the evaporator used to be. A new box will look much cleaner and only retain the blower for your heat. They run $60-130 depending on where you find one. Some people have fabed up their own. You can keep your box now like I said, but it won't look as clean as a heat only box. Hope this makes sense.
Old Sep 17, 2011 | 11:52 AM
Sttn89's Avatar
Car: 89 caprice
Transmission: 700r
yes it does.thanks
jrdturbo
Mar 31, 2016 02:58 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
