Fuel pump replacment question
Old Sep 18, 2011 | 01:38 PM
sundance kid's Avatar
I read somewhere some time ago that a firebird fuel pump was the best unit to use when replacing a fuel pump. My car is a 305 tbi camaro with a holley throttle body. (new) Would the fire bird tpi fuel pump push more pressure than the stock 305 tbi camaro fuel pump.
Old Sep 18, 2011 | 03:45 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Fuel pump replacment question
Welcome to TGO. Odds are that the Firebird TBI & Camaro TBI fuel pumps are the same.
Don't go with a 255lph fuel pump, it will overwhelm a stock system.
A TPI fuel pump works well at the lower pressures that a TBI system run at.
RBob.
Old Sep 18, 2011 | 04:33 PM
thanx for the responce ,does the tpi unit just drop in (same hook ups,wiring)as the tbi unit?
Old Sep 18, 2011 | 05:09 PM
one92rs's Avatar
Car: SOLD!!!!!
yes it does
Old Sep 19, 2011 | 05:23 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Part #
ACD#EP241 (TPI fuel pump)
Old Sep 19, 2011 | 11:26 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
deffinately dont use the 255LPH I installed that sucker with my stock tbi system except for holley tbi unit and i am swapping it for a tpi pump...lame! haha.
Old Sep 19, 2011 | 02:41 PM
thomas1976's Avatar
Car: 91 Trans am
Did you have any issues?
Old Sep 19, 2011 | 06:00 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
yes i am getting inconsistent fuel pressure. and from what ive read its because the return system cannot keep up with the volume of fuel the pump is delivering. so im switching it to a tpi pump. I cant tune if I dont have a consisitent pressure to tune off of ya know?!
Old Sep 20, 2011 | 05:07 AM
thomas1976's Avatar
Car: 91 Trans am
Could you notice the fuel issue after installing the 255 lph pump, before you tryed to tune it?
Old Oct 5, 2011 | 10:49 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Oh kind of an old question. but yes. I installed this pump and at the time i only had a liquie filled gauge on the car and I put it at 20, but it would read all over the place but never over 20. I hooked up a mechanical gauge that I would use at work to test someone's fuel pressure. and it said 50 psi. the car ran decent before the EBL as I had a hypertech chip. but I had a high spark knock count so i figured I needed a real tune. After the tune and with the stock timing curve again, the problem seemed to be uncovered more. But to do a tune I needed to know a constant fuel pressure, and I can't do that with an inconsistent pressure so that is where I am at now.
Old Oct 9, 2011 | 06:29 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
so now the pump has been installed and I can finally have my constant 20 psi I think I need. so I can finally start to tune. yay! haha. I replaced the walbro 255 with an ac delco stock tpi pump.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
