Crank trigger to conrol fuel only
Old Oct 21, 2011 | 07:10 AM
ex-x-fire's Avatar
Has anyone ever heard of guys using a crank trigger to control the fuel signals on tbi engines? This is normally handled by the est distibutor, I wonder if you can then use a vacuum advance distributor swap springs & weights. The timing advance is very conservative on the engines.
I've heard of guys doing this, but haven't seen what they used to make it happen.
Old Oct 21, 2011 | 04:54 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Crank trigger to conrol fuel only
Aftermarket EFI control system
TBI ECM isnt going to use a crank trigger
Old Oct 21, 2011 | 04:56 PM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Seems like a lot of trouble to avoid burning a chip with whatever timing curve you want.
Caspar
Jun 19, 2016 11:19 PM
overdriv
Aug 20, 2015 03:52 PM
Winchester1094
Aug 18, 2015 10:23 AM
