Fuel pump or electrical problems?
Old Nov 27, 2011 | 02:17 AM
RicerEater78's Avatar
I've got an 89 firebird formula that has had a 350 swap. isn't completed yet, just thr injectors, the fuel pressure regulator, and a few little things to get it running reliably. only problem I'm having is that when I turn the car off after a period of driving (+40 min) the pump relay fuse by the battery blows. I'm not sure if its the pump or something electrically wrong with it. anybody have any ideas?
Old Dec 2, 2011 | 02:14 PM
Re: Fuel pump or electrical problems?
bump, anyone?
Old Dec 2, 2011 | 02:19 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Does it blow when you turn it off or when you try to restart it?
Old Dec 2, 2011 | 02:27 PM
it seems to be when I turn it off. id have to test it out to know for sure. and like I said, its only after about 40-45 minutes of driving
Old Dec 2, 2011 | 02:33 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
If it blows when you turn it off, I really do not know what could cause that. Possibly a wiring issue.
If it blows when restarting, when the pump is warm, then I would suspect a pump issue.
Old Dec 2, 2011 | 02:37 PM
it quite possibly could be the pump. its been on there for 130k miles. a dirty fuel filter was suggested to me as well
Old Dec 3, 2011 | 10:01 PM
nope, its happening when I turn the car off. but now more frequently. ill replace the pump and see if it helps. I've gotta change it later on anyways
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
