CFI FUEL RETURN LINE
Old Mar 27, 2012 | 04:31 PM
82_Camaro's Avatar
Car: 82 Z28
Transmission: Turbo 200C
Axle/Gears: 3.43
i have a major issue. the fuel return line on my 82 Z28 was stuck. so when i pulled the motor i cut the line while in the process it shredded the fitting. and now that im trying to rebuild the line i cant find the fitting anywhere. and better yet i cant get Neither NPT or AN fittings to work. does anybody know what the fitting thread size is or where i can find it. i have the big fitting that is direct to the throttle body its the one on the actual line that i need. id prefer to make a steel braided return line because thats what ive done for everything else so far but i will work with a regular stainless line if needed. please help
Old Mar 27, 2012 | 06:09 PM
ex-x-fire's Avatar
Re: CFI FUEL RETURN LINE
I had a crossfire on my 84 vette, the return line was a double flare (no o ring) type, the line is probably the same as those 5/16 lines at the parts stores, US thread.
Remove the fitting from the throttle body & take it with you to the parts store.
Grant2k
Jul 10, 2018 04:01 PM
AkDrifted
Aug 17, 2015 07:45 PM
wayshegoes
Aug 17, 2015 12:00 PM
armybyrd
Aug 10, 2015 09:23 PM
Kaweh
Aug 9, 2015 02:54 PM
