Idle Problems
Old Mar 31, 2012 | 08:39 AM
masterangler88's Avatar
Car: 1988 camaro
Engine: 350 TBI
Transmission: 5 speed
Axle/Gears: Stock
Idle Problems
I have a 88 camaro. Came factory with 305 TBI. Was told when I bought it that the 305 was pulled and a 350 was dropped in. Found GM5.7 stamped into the back of block. The swapper used the original TBI. I was worried about the engine running lean. Tuned it up and checked the old plugs. No signs of a lean mixture. Plugs actually looked good. Anyway the problem I am having is when you start the engine when cold it surges. Revs up to about 1500 rpm and then droppes below 500 rpm. revs and falls, revs and falls for several minutes before calming down and idling at about 800 rpm or so. The problem I am conserned with is after driving the idle jumps to 1800 rpm. The idle will not fall below that until you shut it off and let it cool down. Any suggestions would be greatly appreciated.
This is my first thread or post. Haven't even replyed before. Hope I did it right.
Old Mar 31, 2012 | 03:21 PM
ex-x-fire's Avatar
Re: Idle Problems
Remove the tbi unit & clean all the passages, replace the base gasket, they sometimes go bad.
Old Mar 31, 2012 | 06:58 PM
Car: 1988 camaro
Engine: 350 TBI
Axle/Gears: Stock
Re: Idle Problems
Thanks for the advise. I will have to give that a try.
Old Apr 20, 2012 | 06:09 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: Idle Problems
I would do a vacuum leak test, if you got a leak 9 outa 10 times it will show it, the tbi gaskets are a great start as well
Old Apr 22, 2012 | 08:26 AM
EagleMark's Avatar
Re: Idle Problems
5.0L injectors need to be changed to 5.7L injectors also. But it does sound like a vacuum leak
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
