Starting problem... watch video
Old Apr 2, 2012 | 12:34 PM
ricklovin93's Avatar
Car: 1988 camaro base coupe
Engine: 305 LO3
Transmission: gm 700-r4
http://www.youtube.com/watch?v=isQpT...74AUAAAAAAAAAA
Old Apr 2, 2012 | 01:09 PM
gmstrong's Avatar
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
Re: Starting problem... watch video
make sure the timing is correct.
Old Apr 2, 2012 | 01:19 PM
Engine: 305 LO3
it only does it when its a cold start though, if i drive it around for a little bit and turn the engine off, she will fire right up no problem
Old Apr 2, 2012 | 06:43 PM
1986 iroc z28's Avatar
Car: 89 formula
Transmission: t5
Axle/Gears: open junk
it sounds like its way to rich, i would check the coolant temp sensor for the ecm. Ive also had a number of tbi vehicles with the same issue and it turned out to be a bad map sensor, which can be bad without showing a ses code. map sensors have a rubber diaphram in them which break down and harden up overtime, which causes the computer to read the wrong amount of vacuum.
Old Apr 2, 2012 | 07:27 PM
one92rs's Avatar
Car: SOLD!!!!!
almost sounds to me that there is extra fuel in the intake like the injectors are bleeding down. when it is how it will evaporate the fuel better.
Old Apr 2, 2012 | 09:06 PM
Engine: 305 LO3
i know the check engine light is on ill have to plug in the code key to see what they are maybe the codes have something to do with the problem
Old Apr 5, 2012 | 06:14 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
coolant temp sen.
Old Apr 19, 2012 | 03:28 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
any updates on a solution to your problem rick?
Old Apr 19, 2012 | 08:59 PM
Engine: 305 LO3
well i changed the egr valve, and a new tps and it seems to run and start alot better now, i might change the coolant temp sensor soon though
Old Apr 20, 2012 | 04:09 AM
Flora62's Avatar
Old Apr 20, 2012 | 03:48 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Where did you get your egr valve? Seen a few threads saying get a GM one.
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
StevenB L98/LS1
Aug 22, 2015 09:03 AM
perZ
Aug 21, 2015 05:51 PM
