possible injector problem
Old Apr 5, 2012 | 09:08 PM
hondorian7's Avatar
Car: 91 Chevy Camaro RS
Engine: 305 TBI
ok so my 91, TBI 305 has been running rough and dieing at idle so when i took off the air filter and started it up i noticed one of the injectors was not spraying with a consistent pulse. it has a nive v shape when it does spray but it cuts in and out. so i swapped the sides the connectors are on and the same side still does the same inconsistant spray. i ohm checked the injectors the inconsistant one reads at 1.0 and the other at 1.3 ohms. could this be a bad injector or something i havent checked. any info will help thank you!
Old Apr 5, 2012 | 10:37 PM
Schurkey's Avatar
Re: possible injector problem
If you can switch wire harnesses but the problem stays with the same injector--I don't know how the injector could NOT be defective.
MAYBE it's nothing more than sticky from fuel varnish. You could try a bottle of Techron fuel additive--but realistically, I suspect the injector is toast.
Old Apr 6, 2012 | 11:36 AM
Ronny's Avatar
consider looking at first injector connection FIC they may have a exchange program on rebuilt/cleaned
bryan623
Mar 22, 2021 06:43 PM
Street Lethal
Apr 30, 2019 12:14 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
tmellott89
Aug 16, 2015 02:58 PM
