Which timing set with LT4 Hot Cam
Car: 91 GTA
Axle/Gears: stock
Like the title says, which timing set do I need to use with the LT4 Hot Cam. The one I ordered from Summit doesn't fit (P/N ZKT3499S). Can I use an LT1/LT4 timing set or will the extra gear for the water pump interfere?
BTW this is going in a SBC 350 with TBI.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Which timing set with LT4 Hot Cam
I would recomeend a factory single roller timing set for a ~1998 350 G3500. Same chain & sprokets that are used in the ZZ3/4. crate engines.
Car: check
Engine: check
Transmission: check
Be sure to shorten the pin on the front of the cam so that it doesn't rub on the timing cover.
RBob.
RBob.
Car: 91 GTA
Axle/Gears: stock
Thanks Fast, I've got the right one now.
Rbob, I did that already. Did you have any issues with the end mushrooming on you?
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
The end on mine mushroomed slightly. I just took a file and carefully cleaned it up.
Car: 91 GTA
Axle/Gears: stock
yeah that's what I ended up having to do. I was a little upset about it when I first noticed considering I used an aluminum mallet to push the pin in specifically so it wouldn't mushroom.
1988iroc350tpi
Aug 14, 2015 07:52 PM
