oil pressure sending unit nightmare
Old Apr 11, 2012 | 10:31 PM
andrew91fbird50's Avatar
Car: 89 Formula
Axle/Gears: 10 bolt 2.73
i have been fiddling with this darn thing for about 3 weeks now. i had a mechanical gauge hooked up to it and i got pretty average oil pressure around 30-40 pounds.
i installed a new sending unit and spliced in a new oil switch connector. it didnt work. i removed it and noticed that the new connector from summit had a damaged pin. i also so i reconnected the old connector and then plugged it back in and it STILL doesnt work. it stays very very low and when i turn the key i can hear the fuel pump kick in and the gauge moves up very slightly. when i start it i get nothing.
does anyone know the secret?
Old Apr 17, 2012 | 03:09 PM
peej07's Avatar
Car: 89 RS
Engine: 305 TBI
Axle/Gears: 2.73 1 wheel peel
Re: oil pressure sending unit nightmare
I have a similar issue. Mine was working, then it stopped so I saw it was leaking. I replaced it with a new one plugged it back in and I still get no reading from the gauge.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
