Best Timing Setting for MPG in 350 TBI
Old Apr 14, 2012 | 09:18 AM
ryanross75's Avatar
Has anyone out there ever measured the difference in mpg between 0 degrees and 4-6 degrees. Mine was at 6 and I was using a lot of fuel. Thanks for the time.
Ryan
Old Apr 14, 2012 | 03:33 PM
ex-x-fire's Avatar
Re: Best Timing Setting for MPG in 350 TBI
That timing wasn't too far advanced, usually it gives better mileage at 4-6*, unless the engine is spark knocking. It might be worth a 1mpg.
Make sure the egr system works, tune up parts are good, & the engine gets up to proper temp (190-200) going down the road. Is the check engine light on?
Old Apr 14, 2012 | 06:53 PM
ryanross75's Avatar
Everything is in totally fresh tune. It was spark knocking ever so slightly at that degree range. Mostly in overdrive under strain going up a hill. It also idled not as smooth and low as I would like. Check engine light is not on. Vacuum is steady and the engine runs strong.
Old Apr 14, 2012 | 07:28 PM
Schurkey's Avatar
The knock sensor will pull timing--reducing power and fuel economy--long before you HEAR spark knock.
Put a scan tool on that thing--I bet you see the knock sensor is active at highway speed.
Your fuel economy may IMPROVE with less timing--if it keeps the knock sensor happy.
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
camaro71633
Sep 1, 2015 10:24 AM
InfinityShade
Aug 22, 2015 08:00 PM
