Coils on TBI
Old Apr 13, 2012 | 03:49 PM
chaserob's Avatar
Coils on TBI
Hi, I'm currently installing an open element system and am wondering about the coils. The instruction guide i'm looking out is very clear not to let the base touch the coils. Are those the multicolored wires coming up, or is it something else? Also should i cover the driver side hole where i removed a vaccum with something?
Thanks!
Old Apr 13, 2012 | 07:39 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Coils on TBI
Thanks!
there is one coil on a tbi. do not let the air cleaner touch the coil wire from the dizzy. i cut, shortened, and rewelded my coil bracket.
Old Apr 13, 2012 | 09:40 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Coils on TBI
They sell small bags of vacuum caps real cheap at your local auto parts store. Any hose nipples that are exposed from the throttle body must be caped with one of those. The only hose that should be coming off the TBI is the one connected to the bottom of the stock base you are removing .You don't have to push the cap all the way on .I just go about half way with the cap so its easier to take off when necessary.I'm using a drop bottom base with a 1/2in. plastic spacer to elevate it off of the linkage and the coil. My bottom of the open element(base) is close to the coil wire also but not touching. Even though I still have the wires(mane coil wire and smaller wires) wrapped with plastic wire loom and the bottom of the element closest to the coil is covered with electrical tape.
Old Apr 14, 2012 | 01:33 AM
chaserob's Avatar
Re: Coils on TBI
So the coils are the middle part on what I put the open element on right? There's 4 wires total and those come up to connect to two metal things? Are those the coils?
I started my car and test drove it and everything seemed fine, as in no electrical arcs or anything
Old Apr 14, 2012 | 06:57 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Coils on TBI
i'm pretty sure what your concerned about are the fuel injectors on the throttle body . the ignition coil is what the instruction sheet for your new aircleaner refers to . look at your distributer , center wire on the cap runs to the ignition coil . good luck .
Old Apr 15, 2012 | 05:17 PM
Engine: TBI,5.0
Re: Coils on TBI
The yellow box in the photo (yours will be black if its stock) with the red coil wire coming off the middle going to the center of the distributor cap(again yours will be black if stock) is the wire they are concerned with. You don't want it touching the bottom of the new base plate you are installing. Mine is missing a good inch so I would consider that OK. Even though I still covered the bottom of the base plate closest to the wire with electrical tape.
junior419
Apr 7, 2025 11:35 AM
Johnoooooo
Sep 22, 2015 08:55 AM
timonator
Sep 17, 2015 06:57 PM
Glowsock
Sep 11, 2015 11:09 PM
Jlanz55
Sep 6, 2015 03:05 PM
