91 lo3 fuel pump question.
Car: 91 Firebird Vert
Engine: LO3
Hello, I have a 91 Firebird with a lo3 and automatic. The LO3 is mostly stock, just ignition and exhaust mods. Sadly the fuel pump has died and I need to replace it. Future plans are to swap on the TPI I have for it once I get a harness. So I don't have to drop the tank twice can I go ahead and replace the stock TBI pump with a TPI one or will it have too much pressure for the stock TBI fuel pressure regulator to handle?
-Prime-
-Prime-
Re: 91 lo3 fuel pump question.
You'll be ok, the tpi pump only makes more pressure if regulator is for higher pressure. I like to use the same year tpi pump as your oem. I did this on my buddys truck this past weekend, 88 gmc truck, used a 88 irock tpi pump, plug n' play.
Did you have to adapt the outlet of the pump to the sending unit pipe? The original pump had a 3/8 outlet, the 241 uses a 5/16 outlet. Finding a bit of hose that would stretch over the sending unit tube while still fitting
the fuel pump outlet was...interesting.
Car: 88 firebird convertible
Engine: 305 tbi v8
take advantage and see how corroded your tank may be or may not be.. if you see any rust or "tar" in the tank i highly suggest to change it. i blew through 2 pumps because of that. now i got a new tank and a tpi fuel pump car runs awesome. lmk if you need a tank i have a new one just sitting still in its box.
Engine: gone
Transmission: gone
Axle/Gears: gone
pump will work no problems. you'll be set for awhile with that pump. but if you do to crazy of a tpi setup you'll eventually need even more pump.
Engine: LO3
Engine: gone
Transmission: gone
Axle/Gears: gone
Engine: 305 tbi v8
sup with your fuel tank??? you might wanna kill two birds with one stone. these cars are 20 years+ and most likely on its factory tank. mine blew out three pumps before i changed it all together. now runs fine. (sorta, bad esc now).. i know where you can get a tank chea if your interested. lmk
92camaroJoe
Aug 13, 2015 06:07 AM
