fuel pump problems
Old Apr 25, 2012 | 03:15 PM
kylet8020's Avatar
Car: 88 iroc
Engine: 305 tpi
Transmission: unknown atm
Axle/Gears: unknown atm
fuel pump problems
I got a 88 camaro 305 tpi, been working on lil problems with it for the past 2 weeks brakes being the biggest one. My problem is I'm working on a crank no start, I've checked the relays all good, fuses are good, pump is good I think put power right to the plug for the pump it seems to be working hot 12 to gray wire grounded the black wire. I went to release the pressure but no fuel came out*more on this in a sec last thing for me to check atm is power back to the pump connector. Anything else I should try and check? Or anyone got any ideas I've been reading all the posts on this problem and followed advise given.
This is crazy, been runing *not fine* the last few days. I'm lost on this left the hood open and now have this prblem the under hood light killed the battery.... don't think that's the problem but that's what has brought this about.
Old Apr 25, 2012 | 04:31 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: fuel pump problems
I had this "problem". It would crank but wouldn't spit fuel from the injectors. There are two wires that connect to the battery, that allow the injectors to fire. I replaced my fuel pump, filter and relay before realizing the two wires I thought were grounds, needed to be connected to the positive terminal on the battery. Fired right up. Let me know. I'll post pictures of the wires I'm talking about in a few minutes.
Old Apr 25, 2012 | 04:59 PM
kylet8020's Avatar
Car: 88 iroc
Engine: 305 tpi
Well I checked the connetor from the car to the pump fuel pump is gettin power.... I put my voltmeter in as if itwhere the pump to see what power I'm gettin.. and the injectors are gettin power... but no fuel. Fuel lines are not the problem I know this couse I'm gettin fuel every now and then to the pressure relase valve. Could this be a signal wire problem? Btw I did post thi in the wrong part of the fourms should be under tpi not tbi my bad... but I'm willing to bet that the fuel systems are very close to the same if not the same... I'm goin to start losing my hair..... I'm also bout 5 mins from seling this and goin back to a ford, but then again I wana drive this car more I really like it.. lol what to do what to do.
Old Apr 25, 2012 | 05:09 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Oh, got you. I posted the picture of what I was talking about anyway, so at least there is some clarity if someone should fall upon this thread later on. Be sure to post the results.
Old Apr 25, 2012 | 07:06 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
possibly a weak fuel pump?-once a friend had a no
start problem with a ~1995 chevy blazer,turned out
the injecters needed a minimum pressure to operate-
they would not flow below that minimum,a new fuel
pump fixed it.
Old Apr 26, 2012 | 06:38 PM
kylet8020's Avatar
Car: 88 iroc
Engine: 305 tpi
Problem is I'm not gettin any fuel to the fuel rails... I'm lost at this point...
Old Apr 28, 2012 | 01:39 PM
goliath88's Avatar
Car: 88 firebird convertible
Engine: 305 tbi v8
you check the fuel lines for blockage?? its not unheard of with these cars. i blew my lines out with a compressor last time i was doing work on it, some particles came out. but then again my tank was "effed" up.
food for thought.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
