Is oil additive needed in 83 camaro
Old Apr 29, 2012 | 09:12 AM
aguynsd's Avatar
Car: 1983 Z-28
Engine: Crossfire Injection 305
I was listening to the radio and they were talking about older cars needing oil with zddp, I was wondering if 1983 camaros fall under this category? Do they have flat tappet or roller camshafts? Also what additive would be the best chioce? or oil would be the best choice?
thanks
Old Apr 29, 2012 | 01:10 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Is oil additive needed in 83 camaro
'83 is flat tappet-zddp could help,but it is especially
important for breaking in a new flat tappet cam/lifters.
A soon as i became aware of the zddp issue,i started
to use oil i knew had higher zddp such as shell "rotella"
recently i have heard zinc is reduced in that too,so i
have some old vintage '80s 20w"fortified with liquid
zinc"oil that i add 1 QT of when i do an oil change-
bought this stuff(in cans)at a flea market.
Old Apr 29, 2012 | 06:09 PM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
83 is a flat tappet motor, I would add it.
Old Apr 29, 2012 | 06:34 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
My motor is also a flat tappet.
Has anyone here ever tried ZDDPlus?
Old Apr 29, 2012 | 10:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The problem with pouring random quantities of zddp additive in is that you'll contaminate the O2 sensor and converter.
Old Apr 29, 2012 | 10:12 PM
Car: 1985 Z28
That's assuming I have a converter.
I thought that only lead was harmful to o2 sensors.
Old Apr 30, 2012 | 03:26 PM
Ronny's Avatar
I use Lucas oil additive (12 oz bottle) which is different than their oil stabilizer(24 oz bottle).
1992 Trans Am
May 10, 2023 07:19 PM
IROCZ1989
Jan 24, 2016 03:55 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
