Anyone run CAM II in their CFI ?
Old May 2, 2012 | 08:11 PM
Coyote850's Avatar
Car: '83 Z-28
Engine: 5.0 CFI
Transmission: 700-R4
My '83 Z-28 runs really good. (Not joking, really) A buddy at work said I might wanna run alittle CAM II threw it to clean it out. Just curious if I might do some damage to the CFI by running that high of octane threw it.
Old May 2, 2012 | 08:29 PM
AJs91camaro's Avatar
Car: 91 camaro rs
Engine: 305tbi,lunati cam, vortec heads
Re: Anyone run CAM II in their CFI ?
Cam 2 fuel is great to use in a carb motor. Cam 2 is a leaded fuell that will help clean the valves and it is 119 octane from the pump. The only down sides to it is, it doesnt alweays pass through the fuell injectors well and it can clog up in the exhaust converter if your running one. so in short if you have a carb motor and no caty converter your 100% fine and I would use it. We have it in ohio at a gas station in boardman ohio
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
355tpipickup
Aug 13, 2015 07:35 AM
