missing on one cylinder ?
Car: 1992 rs stock for now
Transmission: auto
my back cylinder on the pass side of my 305 tbi is not firing i checked the spark pug its good it has compression the spark pug wire and rotor and cap are good to but it still wont fire any clues on what else could cause this
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: missing on one cylinder ?
Is the spark plug and spark plug wire for that cylinder new or what? Sometimes they may look good but still be defective.
Transmission: auto
rotor cap wires and all spark pugs are new practically i had the car at school it rarely was driven except for the three hr drive back home for holiday breaks
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Is the cylinder getting air and fuel? I know you said it had good compression. Only thing I can think of is that its firing but not getting fuel due to a blockage of some sort. Have you tried changing the plug just in case. Some of them can get a hairline crack. I know I had bought a set of accel header plugs and more than half wouldn't fire. I changed them to delcos and have had no problems since. Ngk are good too
Car: 1991 Z28
Engine: 355 TPI
May be a good idea to check the plug wire with a volt meter for continuity
camaro1185
Oct 26, 2015 06:51 AM
