Intake options for TBI w/Vortec heads?
Car: Pontiac
Axle/Gears: 3.08 / Drums
It's been a while since I've looked at this sort of thing, but are there any alternatives to the GMPP TBI intake? It seems very pricey relative to both standard TBI intakes and carbureted Vortec intakes.
I don't care about the EGR thing so much, but I don't want to go the whole hokey, bolted-together-adapter-plate route, either.
I remember hearing rumors on here some time ago of a mythical Vortec TBI manifold that could be found in 1996 2500 and 3500 G-vans- did that ever pan out?
Re: Intake options for TBI w/Vortec heads?
Edelbrock makes a Vortec 2 barrel carb intake that one could add an adapter plate to.
http://www.summitracing.com/parts/EDL-2912/
Car: 92 GMC K2500 LD
Engine: 350 TBI with some mods
Transmission: NV4500
The GM one is the only one I know of. You will be messing with adapter plates with anything else. I was going to use vortecs with my truck but decided I didn't want to fool with them to get it all working. I wanted to keep my TBI and EGR.
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Grab a regular edelbrock rpm performer for vortec heads or similar knock off and then add a 4bbl to tbi plate. The victor Jr manifold is designed for 3k to 7k rpm operation not good for tbi
This or similar should work
http://www.ebay.com/itm/Edelbrock-71...483d9c&vxp=mtr
Here is a knock off version
http://www.ebay.com/itm/SBC-CHEVY-VO...60da7b&vxp=mtr
Then get an adapter
Here are a bunch
http://www.tdperformance.com/Carburetor-to-TBI-Adapters
http://www.ebay.com/sch/items/tbi+ad...=445962_446022
Then get an adapter
Here are a bunch
Car: 1983 G20 Chevy
Transmission: 4L60
Says who???? Victor Jr 2bbl is IMO the absolute best 2bbl TBI intake out there. You will make the same torque as a dual plane and alot more HP.
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
There's a guy in the for sale section that is selling a few of them and at a good price. I just bought a GM Performance intake for mine and it was 300 used 385 to 405 new. Or you could go the adapter plate which I didn't know about till I already bought the intake and sold the performer that was on it.
I'll sell you my GMPP intake for $250 plus shipping. The only problem with it is the dist. hole is a little wallared out on one side. (I'll send you a picture if your interested) That should't make a difference. I have cleaned and bead blasted it and plugged the un-nessory holes, and even made a block off plate for the EGR if you don't wan't it.
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
is anyone still selling vortec heads redrilled for the standard intake?that and a new chip seems to be the best way to get by the smog police.
Shipping will suck.
PM for details.
Car: Pontiac
You think so? I wonder if once the neccessity for a strong vacuum signal to each venturi is removed, the single and dual planes become much more equivalent. In my case, I will never see the high side of 5800, so I am curious if the Victor Jr. is really as good at say 1250-4500 rpm
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
For vortec applications uses EDL-2912. The photo below is for Vortec heads. EDL-2912 is drilled for square bore and for model 2300 Holley carbs used in Ford applications.
http://www.edelbrock.com/automotive/...ds/sb/2912.jpg
There are a lot of adapter plates out there that can possibly work, but there are several design details that must be taken into account:
www.ihpartsamerica.com%2Fforums%2Ffuel-injection%2F4263-faq-parts-required.html&ei=x-JDVNKtFc2bigL7tIDYBA&bvm=bv.77648437,d.cGE&psig=AFQjCNHbWV71m-4thdLG1YCB6mrspUtNIw&ust=1413821455145954
1) Holley Part# 17-47
https://rspimages.holley.com/17-47.jpg?width=583
2) DCtrumpet TBI to 4150 square bore adapter plate. eBay item number: 231311057274
http://i.ebayimg.com/00/s/NjAzWDU2OQ==/z/eUQAAMXQfj9SMzuY/$T2eC16JHJIUFHHkJoB46BSMzuYk6+!~~60_57.JPG
I like #2 - it is CNC machined from 1/2" 6061 AL and has plenty of thickness for bolts to engage into. No vacuum leaks, looks great.
//RF
//RF
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Engine: L03 305 TBI
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1983 G20 Chevy
Transmission: 4L60
This unit is similar but not water heated.
http://www.summitracing.com/parts/hly-17-47/overview/
Engine: L03 305 TBI
Car: 1983 G20 Chevy
Transmission: 4L60
Engine: L03 305 TBI
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1992 Camaro RS
Engine: 5.7 Vortec with TBI
I used the GMPP intake on my Vortec conversion. Retained EGR and AIR systems. I have to say I am very happy with the results. Used the 89 Cop car injectors and had a chip burned to make it all work together. Runs really smooth. Nice idle, great power...no regrets.
