single plane intake
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
single plane intake
looking for some input. I am currently running a dual plane edelbrock intake on my tbi(mods in sig) but with the 113 heads there is no exhaust crossover which is causing some idle consistency issues at cooler temps. I read that the single plane intakes are better suited for these types of issues than the dual plane. I am looking for confirmation of this and possible issues I may be missing that single plane intakes have/cause.
Re: single plane intake
idle consistency issues at warmer temps.
I believe the single plane offers better distribution to cylinders.
I run a Holley Projection dual plane currently.
Engine: Built ls1
Axle/Gears: 3:42
Thanx for the feedback, I wasnt really looking to change manifolds again unless it was absolutely needed. I'll stick with what I have for now and tune it as best I can, which I bet will slightly change with cold weather and hot weather.
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Sounds like you are refering to EGR, in wich case, will probably have nothing to do with the "warm idle inconsistency".
im not using the exhaust crossover on mine. got the egr tuned out and blocked off. egr is not working during idle. your inconsistant idle is being caused by something else.
Car: 91 Trans am
And even if the EGR valve was there and operating during an EGR event, nothing would happen. The valve would open, and thats it.
Engine: Built ls1
Axle/Gears: 3:42
No I am not referring to the Egr valve, nor is that the cause of my issue. My issue is that when cold there is no heat in the intake which causes irratic idle due to no exhaust crossover but once warm the idle settles down and becomes more consistent. It isnt a large problem it just means i have to let the car warm up for a few minutes before driving it. I can probably tune it out or atleast better.
Car: 1983 G20 Chevy
Transmission: 4L60
I don't know of a single V8 TBI intake that had an actual heat riser crossover passage under the TBI. The V8 intakes all had water heated passages. The EGR port was only connected to the passenger side head and feds the EGR valve only.
Engine: Built ls1
Axle/Gears: 3:42
Ah good to know. Switching over to a single plan would not be worth while and I'll have to work on tuning it in.
Car: 91 Trans am
It is the heated cooling water that warms up the intake manifold.
Most likely your car is running lean when its cold, you might want to make you regulator adjustable & bump it up a lbs or 2. You'll need a gauge to do that.
I've heard of guys putting a quater under the regulaor spring for alittle bump in fuel pressure.
Engine: Built ls1
Axle/Gears: 3:42
Rbob set me up with a good alternative to solve my issue. I am going to tap into my intake where the crossover is on the intake and run coolant to and from it to heat up the intake. He wrote a thread about it and did it on one of his vehicles to solve a similar issue.
http://www.thirdgen.org/techboard/tb...gle-plane.html
I am running a vrfpr with the ebl and it has been tuned pretty close to steady idle but still slightly fluctuates when cold because of poor fuel vaporization.
Throttle plate icing is what we have happen in my part of the world. The fix that I use is the stock thermostatic controled air cleaner with the tub down to the manifold, or in my case a tube on the headers.
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
