Need help identifying these parts after swap
Old Aug 9, 2012 | 10:40 PM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
I'm finishing up my 305 to 350 swap and I remembered where most everything goes except for these two parts. The first connector I can't seem to find a place for anywhere. All my sensors and other electronics are accounted for (as far as I can tell)...The second is a ground, but to what? I can't for the life of me remember where I took this off of the car and if I still need it. Any help you guys can give would be much appreciated.
Attached Thumbnails Need help identifying these parts after swap-img_5436.jpg   Need help identifying these parts after swap-img_5438.jpg
Old Aug 9, 2012 | 10:57 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Need help identifying these parts after swap
Second pic,
Ground from passenger side head to firewall
Old Aug 9, 2012 | 10:58 PM
Car: '87 Camaro
Second pic,
Ground from passenger side head to firewall or top trans bolt
Car: '87 Camaro
Second pic,
Ground from passenger side head to firewall or top trans bolt, one of those 2 places
Old Aug 10, 2012 | 10:56 AM
Car: 91 GTA
Axle/Gears: stock
thanks t-top havoc...After doing some searching I believe that the connector in the first pic may be for the EGR solenoid but I haven't been able to find any descriptions or pictures of the connector. Can anybody confirm this?
Old Aug 10, 2012 | 01:34 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
EGR solenoid plug should have PINK-BLK and Gray wire.
//RF
Old Aug 12, 2012 | 02:35 PM
Car: 91 GTA
Axle/Gears: stock
yep thats what it was. Thanks RF.
I have one more question if anybody knows it. I have a vacuum tee fitting with a short piece of 1/4" vacuum hose coming off one end and I don't know where it goes. One end of the tee goes to something (don't know what it is) near the evap canister and the other goes through the firewall. I just don't know where/what the 1/4" line goes to.
Linson
Aug 21, 2015 02:12 PM
355sbcTPI
Aug 19, 2015 04:38 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
