rpms jump up and down
Old Sep 21, 2012 | 03:24 PM
littlevin91's Avatar
Car: 1991 camaro z28 convertible
Engine: 5.0 v8
Axle/Gears: 9 bolt 3.23 borg worner
I changed the manifold on my motor. When i put everything back together i started the car set the timing and the rpms will go up and down i get no throttle responce at all. Ive changed the fuel filter, cap and rotor, the iac in the tb and nothing has worked
Old Sep 21, 2012 | 04:52 PM
onebad92's Avatar
Re: rpms jump up and down
what do you mean by no throttle response at all?? like it wont rev up in neutral?
Old Sep 21, 2012 | 07:48 PM
Engine: 5.0 v8
Itll rev in neutral and park no problem but it i put.it in drive or anyother gear n give it gas the rpms drop and.it dies
Old Sep 22, 2012 | 12:59 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Make sure all your vacuum lines are connected and make sure the timing is correct. DISCONNECT THE ESC PLUG TO SET TIMING TO ZERO! Then turn off and reconnect ESC and see if it helps.
Old Sep 22, 2012 | 10:16 PM
Engine: 5.0 v8
all the lines are connected and when i did the timing i unplugged the est and the timings on
Old Sep 23, 2012 | 09:31 AM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
What manifold did you put on? If its not a stock one, or close to it, you may need to do some prom tuning.
Old Sep 23, 2012 | 07:15 PM
Engine: 5.0 v8
its a stock tbi manifold my dad picked up from a junk yard
camaronils
Sep 20, 2015 02:57 PM
wisemanz28
Sep 20, 2015 01:26 PM
pacoelrapido
Sep 11, 2015 02:41 PM
Stroopwafel
Sep 11, 2015 06:38 AM
