fuel pressure with vfpr acting funny
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
I installed the VFPR on my camaro and as you open the throttle the fuel pressure goes up like it should but after a second of holding the throttle open the pressure drops back to its idle pressure. normal? vaccum leak? If i keep opening the throttle slowly the pressure goes up but once I stop it goes back down. I could have sworn it was supposed to go up relative to throttle position.
Car: check
Engine: check
Transmission: check
Re: fuel pressure with vfpr acting funny
No, the fuel pressure follows the intake manifold pressure. As the RPM goes up without a load, the manifold pressure drops like a rock.
RBob.
RBob.
Oh gotcha. I cant see the guage while im driving. Thought there was something wrong.
Another question for ya rbob. The ebl utility that calculates the bpc values. What fuel pressure do i enter when using vpfr. The idle pressure or open throttle pressure?
R3500
08-17-2015 12:16 PM
92camaroJoe
08-13-2015 06:07 AM
