Holley TBI Adapter Plate?
Car: 1992 Camaro RS, 2012 Camaro SS 45th
Engine: L03 305 TBI V8, Blown 6.2L LS3
Transmission: 700R4, TR6060
Axle/Gears: GM 7.6" 10 Bolt 2.73
I have to put new intake manifold gaskets on my LO3 305, so I figured i might as well buy a better intake manifold for it while its all taken apart anyway to replace the **** part that GM used. BUT, since the LO3 is a TBI system, I either have to use a special intake manifold built for the TBI system, or use an adapter plate on a carbureted intake. Now, this is what I'm not sure about; can the Holley TBI adapter plate be used on the edelbrock intake manifold? I would much rather use this technique for replacing the intake manifold then buying the TBI intake from edelbrock for $100 more then the carb intake manifold. I'll put the links to the parts below. Also, I will be using the factory TBI from the LO3
http://www.holley.com/17-41.asp - adapter
http://www.jegs.com/i/Edelbrock/350/2104/10002/-1 - intake manifold
Re: Holley TBI Adapter Plate?
When I was spending my own money, I opted for the Genuine GM TBI-to-Spread-bore adapter from a late-80's 454. It's taller, and has provision for heating it via engine coolant.
I'm not a fan of the Holley adapter, I think they've placed the TBI too far forward for best fuel distribution. That's a hunch, not a verified fact. Take your chances.
Looks to me that the Holley adapter he's linked to will fit either spread- or straight-bore manifolds.
The manifold he's linked to is drilled for spread- or straight-bore carbs.
evilstuie
Jan 9, 2020 08:29 PM
