Removing Emission Control
Car: 1983 Camaro z28 crossfire injection
Engine: 305 tbi
Axle/Gears: 10 bolt 3.23
I have a 1983 camaro Z28 with the 305 crossfire. I was wondering if there was a way to safely remove the emission control units without messing with my engine. Any and all advice is appreciated. Thanks
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Removing Emission Control
on my crossfire,i removed all the A.I.R. equipment ;smog pump,diverter valve and associated plumbing with no ill effects at all
Did keep the EGR and canister purge working as those have benefits(the canister purge at least)and that stuff wasn't in the way like the A.I.R.stuff was...some have deactivated the EGR and reported no problems.Naturally get rid of the catalytic converter if it is still there
If you have to ask about how to do it, you probably don't realize that you aren't losing any power or performance due to the emissions equipment.
You probably also don't realize that it's against FEDERAL law, so even if they don't test emissions locally, you can still get in trouble if someone in Law Enforcement wants to **** you off.
Mostly, removing emissions controls is just pointless.
Engine: 305 tbi
thanks for the help, I will get back to you if I run into anymore questions
Street Lethal
Aug 12, 2015 11:33 AM
