need help with fuel pump
Old Jan 29, 2013 | 09:27 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
i cut a hatch in the trunk area now i'm stuck how do i get the fuel pump out . heres a pic of what i'm looking at ...
Old Jan 29, 2013 | 09:31 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: need help with fuel pump
wow, nice hack, cut the lines and remove the lock ring.
Old Jan 29, 2013 | 09:36 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
i used a cut off wheel to cut the hatch . can i use this or will i blow up ? how do you remove the lock ring ?
Old Jan 29, 2013 | 10:19 AM
Engine: Lb9
Transmission: M20
the locking ring moves counter clockwise, If you can get a tube cutter in there yeh if not a hack saw. You might want to use union fitting to go back together. Im not a fan of hacking cars I would rather take more effort and do the job correct.
Old Jan 29, 2013 | 10:51 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
i've decided to wait till i put the new rearend in after the turbo install . i can weld a panel to fix the hole i just cut . i got a really bad feeling about cutting the lines . thats for your help tho .
Old Jan 29, 2013 | 10:53 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
i was hoping i could unhook the lines without cutting them , cal me a ***** i guess but getting blown up doesn't sound like fun
Old Jan 29, 2013 | 11:15 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Yep, there it is...now what's next?
Old Jan 29, 2013 | 11:18 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
t70 turbo install , hen the rearend / fuel pump !
cars already on ramps for the turbo install
Old Jan 29, 2013 | 11:23 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
as far as hacking the car i'm not opposed to that with this car . it's my joe dirty ebay budget baby .lmfao !
it will never be a show car or even pretty for that matter . but what it will be is fast an handle like it's on rails when i'm done .
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
