Loss of power after setting timing
Old Feb 20, 2013 | 08:54 PM
oldschoolchevys's Avatar
Car: 1992 Camaro RS
Engine: 5.0
I have a 91 rs 5.0 and I set the timing to about 4 degrees advanced and it ran excellent the next day or so I noticed a loss of power so I reset the timing to about 3 degrees advance and it ran great until the next day. Any ideas or suggestions? Thanks for any insight.
Old Feb 20, 2013 | 10:19 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Loss of power after setting timing
Are you following these steps = https://www.thirdgen.org/settingtiming
I don't have a scanner so I have to do the last step under load and by ear.
I run mine at 4* advanced and it will jump off the line. Thats were you will feel it,off the line it will have a much nicer throttle response. Of course having a 3.42 ratio doesn't hurt either.
Old Feb 21, 2013 | 06:28 AM
ex-x-fire's Avatar
Maybe you have other problems, like tune up parts, low fuel pressure,ect.
Old Feb 21, 2013 | 11:39 AM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
may be a dumb question, but did you remember to retighten the distributor hold down bolt after setting the timing?
Old Feb 25, 2013 | 09:14 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
That's what I'm thinkin too .. It's gotta be tight ! When u rev the engine the cam will actually turn the distributor and change ur timing if its loose .. Sometimes it can even turn a * or 2 and settle back to where it was at idle
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
