Carb to TBI
Old Mar 8, 2013 | 05:57 PM
3rdgensilverRS's Avatar
Car: 1989 Camaro & 2005 Silverado
Engine: 305 TBI & 5.3 Vortec
Transmission: 700R-4
Carb to TBI
I have a 305 TBI and plan on buying a crate motor 350 from summit with all the goodies (ie carb, dizzy, and everything else with a turn key crate)
Big questoin is.....
Can I use my stock TBI unit with upgraded fuel pump and all the stuff I need to switch to 350 (ecm, knock sensor, blah blah blah..)
I wanna keep that MPG good even with the 350..
Old Mar 8, 2013 | 06:44 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Carb to TBI
I would just get the short block and yes, bolt the complete intake you already have on it.
350 is a vague description to address fueling, though L05 and L03 use the same fuel pump.
Coustom chip/ tune, ECS, Knock sensor and injectors, is al you need for a basic L05 swap, here it the sticky tread covering it https://www.thirdgen.org/forums/tbi/...-350-swap.html
Old Mar 9, 2013 | 05:26 PM
Re: Carb to TBI
Thanks!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
