Car dies, need suggestions...
Old Mar 22, 2013 | 02:14 PM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
My moms 89 has a L03 tbi, when driving it drives ok, but it dies every now and then.
We bought it and had no fuel pressure but it still ran, upon removing the carpet in the hatch area, theres a plate with bolts and silicone, under was the gas tank. We looked at the pump and the hose they used in the tank was being dissolved by gas, so we replaced it with proper gas hose.
Still no pressure when we hook up a tester, but steady streams come out of the tbi, whats up with that?
Old Mar 22, 2013 | 05:12 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Car dies, need suggestions...
TBI fuel pressure is 9 to 13 psi. Need to check it on the larger of the two lines to the TBI. It will be the feed line on the driver side of the TBI unit. Easier to check it at the frame to engine hose.
If the pressure is less then 9 psi, it may be a bad fuel pump, or the FPR spring is broken. Can pinch the return hose to see if pressure builds. If not, FP, if so, the FPR spring.
RBob.
Old Mar 25, 2013 | 05:04 AM
Jk_Under's Avatar
Engine: 305 5.0L
RBob.
You seem to know a bit about tbi lol. What does the FPR spring do? where is it located? And on a pressure test, i get nothing on the gauge, but the car runs.
Old Mar 25, 2013 | 07:03 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The FPR spring is part of the FPR, it sets the fuel pressure. It is located at the top rear of the TBI unit, in the can that hangs down from the injector pod.
Getting nothing on the gauge and having the car run isn't really all that unusual. The gauge could be bad, or it is a high pressure gauge that won't register that low (1 - 2 psi is enough to have the engine run).
Did you try pinching the return line?
RBob.
Old Mar 25, 2013 | 08:23 AM
Jk_Under's Avatar
Engine: 305 5.0L
Its a fuel pressure tester gauge from auto zone lol, and i
ll try pinching the return line, haven't thought of that. Thanks.
Old Mar 25, 2013 | 08:26 AM
Jk_Under's Avatar
Engine: 305 5.0L
Oh forgot to mention, spring is good, we rebuilt the tbi unit with new gaskets and rubbers, and the car was doing this before we rebuilt it so you know lol
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
