VSS pulse stenght?
Old Apr 5, 2013 | 04:04 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
VSS pulse stenght?
i have a '92 camaro thats a 305 tbi, factory with auto. what is the pulse from the VSS to the ecm? 2? 4? will 8 pulse/revolution work?
i need to now bc i swapped in an 86 t-5 and looking for the adaptor to put on but am finding 2,4,8 pulse that will fit.
Old Apr 5, 2013 | 08:40 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: VSS pulse stenght?
To the ECM is 2K PPM digital signal. From the VSS is a 4K PPM magnetic signal. There is a 4-out buffer box between the two for signal conversion.
For the T5 you need a stock '90 - '92 T5 VSS + gears.
RBob.
Old Apr 5, 2013 | 09:27 PM
DARKmj16's Avatar
Engine: 305 tbi
ok so i need the 4k PPM, thanks.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Hal87
Sep 26, 2015 09:26 PM
