Is this 350 intake too restrictive?
Old May 19, 2013 | 03:47 PM
ktthecarguy's Avatar
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
http://detroit.craigslist.org/okl/pts/3734191457.html
Hi there,
I am looking for an intake manifold for my engine. It's a built 355, 1969 block with speedway pistons, ARP bolts throughout, etc. With 1970 Z28 double-hump heads, pushrod guides and holes enlarged for .498 lift.
My question is, would this intake be too restrictive? Are 350 and 305 TBI intakes the same?
Old May 19, 2013 | 04:07 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Is this 350 intake too restrictive?
Well that intake is for center bolt cylinder heads which you are not running. If you're going to run TBI on that engine then get a performer rpm for up to 86 cylinder heads and do not get the air gap version. You can find those intakes all day on craigslist. Then run a 4 bbl carb to 2 bbl TBI adapter plate.
Old May 19, 2013 | 05:50 PM
On Probation
Hi,
Thanks for the reply. And thanks for the info. I didn't see that it was the wrong style. sounds like a good idea, that Edelbrock intake. They make good power with carbs.
Jake_92RS
Jan 28, 2020 10:37 PM
michealleger
Aug 26, 2015 03:29 PM
Eric-86sc
Aug 24, 2015 09:01 PM
sreZ28
Aug 14, 2015 07:48 PM
st.evel07
Aug 13, 2015 06:15 PM
