84corvette vs 83 z28 manifold & tbi
Old May 11, 2013 | 03:56 PM
loujon's Avatar
can I replace my 1983 z28 manifold w/tbi with a 84 corvette manifold w/tbi? arev they the same? please explain.
Old May 11, 2013 | 09:38 PM
n1ffer's Avatar
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
Re: 84corvette vs 83 z28 manifold & tbi
I believe the 83 and 84 are the same crossfire intakes. The 82 is slightly different. I have heard the injectors are different for the Corvette, however I have not validated that myself.
Old May 11, 2013 | 11:21 PM
82tarecaro's Avatar
The later intake has some sort of balance holes in the runners. Corvette does have larger injectors. The intakes are the same between the 305 and the 350 engines.
Old May 11, 2013 | 11:43 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Yep,pretty much as stated above-no manifold(or throttle body) differences from305 to 350 CFIs but later manifolds,around late-82 through '84 have the balance holes. proper Modification/porting of a crossfire manifold wakes a CFI right up
Old May 20, 2013 | 11:39 PM
loujon's Avatar
can I swap my 83 z28 manifold with the 84 corvette manifold? what about the throttle bodies and fuel injectors - can I use the tbi units of the 84 corvette on the 83 z28?
Old May 21, 2013 | 07:53 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
you can swap the manifold-they are exactly the same,the TBIs are the same too as is the ECM.The corvette injectors are different flow rate-sized for 350.
MustangBeater20
Oct 29, 2022 09:20 PM
anesthes
42
Oct 24, 2015 07:30 PM
Dwayne614
Sep 28, 2015 08:33 AM
db057
Sep 4, 2015 07:57 AM
transaero
Aug 31, 2015 01:14 AM
