305 v8 TBI surging and rough idle
Old Aug 6, 2013 | 10:47 AM
TheBallPlayer's Avatar
Car: 1990 Camaro RS
Engine: 5.0 TBI Edelbrock Intake
Axle/Gears: 3.73 Posi
Hey everyone, I'm tired of looking at my thirdgen camaro sit in the garage and collect dust due to the problem I'm having. My engine will start up, surge right away and die. Sometimes it will idle, most of the time it won't. The only way to keep it running is to stay on the gas. The engine sounds okay, there aren't any knocks. When I drive the car it stalls out unless put her in neutral, that usually keeps her running. And if you press on the gas just a little bit it bogs down severely. The only code I'm getting off the car is code 12, so I'm not getting much help from that. I've already replaced the oxygen sensor at the ex. Manifold(old one was broke off) I don't know what to go after. I appreciate any help I can get on this, thank you.
Old Aug 7, 2013 | 12:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
I'm going to move this to the TBI forum, where people are more familiar with the particulars of that system.
But, first thing I'd check is the EGR valve to make sure it isn't sticking open.
Old Aug 7, 2013 | 02:00 PM
gearhead141's Avatar
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Possible fuel starvation
I agree with Five7kid in that it certainly could be the EGR. Another problem could be bad gas or a clogged fuel filter. If you've never changed the fuel filter under your ownership, try that first. Even if the EGR is good, the mounting gasket may be allowing a vacuum leak.
Old Aug 7, 2013 | 08:29 PM
Schrade's Avatar
Re: 305 v8 TBI surging and rough idle
DOES sound like a vac leak...
Originally Posted by Schrade
Vacuum leak detection is hard to do right: I know of only one guy who did it right and found a leak (in IAC gasket):
Originally Posted by Schrade View Post
No one got the proper technique for vacuum leak detection...
FIRST (fully warmed up motor); block the gas pedal, or block the throttle linkage. YOU HAVE TO DO THIS TO GET A STEADY IDLE , around 1,250 rpms, or a little higher. If you don't, you can fish starting fluid, a propane hose, or WD40, or Krylon, or hair spray, or pee, anything, until you need a sweater in Hades, but if the motor is lopin' idle already from a vacuum leak, you ain't gonna' find any leak, unless it's so big that Little Jack Horner can stick his thumb in it and pull out a pineapple NOPE.
AFTER you get a steady idle, THEN, you can spray starting fluid everywhere - that's the best detector, because it's vapor pressure is very high - a LITTLE at a time, all around the motor, until you get the rpm SURGE. Follow the vacuum lines to the EVAP cannister too. You might even have to follow the EVAP lines from the EVAP cannister to the gas tank too, but that vacuum leak will show up as a DTC 32 EGR fault, and won't normally show as loping idle, unless the EVAP cannister has been by-passed (been there, saw that uh-HUH yup).
If you get a surge in a tight spot, and can't tell exactly where it is, light a book of matches, blow out the match heads while they're still burnin', and feed the smoke to the tight spot to see it get drawn in.
Fear not the starting fluid; you cannot put the can down fast enough and light the matches fast enough to catch the starting fluid, because the vapor pressure is so high.
Bookmark this post YUP.
Wrench Wizard OUT!
Old Aug 7, 2013 | 08:55 PM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
99% of the time its a bad hose at the fuel pump to the sender causing almost no pressure. Get a this fuel pressure tester and check it. Should be between 9-13 at idle. If its not you can't start with the fuel filter and recheck but you will most likely end up replacing the pump. Happened to me 4 times over 6 years.
Old Aug 8, 2013 | 12:26 PM
Car: 1990 Camaro RS
Thanks for the input. Ive just replaced the plugs and wires yesterday and the engine seems to sound smoother than it did before, there was a plug wire that was seared. I've already replaced the fuel line and the fuel filter, I replaced the side of the line that goes from the fuel filter up to the front of the car. My egr valve isn't sticking open either. What does the egr do when it's working properly?
Old Aug 8, 2013 | 10:37 PM
Axle/Gears: Stock
Check Fuel Pressure.Im Betting Thats What It Is.
Old Aug 9, 2013 | 11:35 PM
Car: 1990 Camaro RS
I'm going to check the fuel pressure as soon as I get te gauge.. I'll post up the results after
Old Oct 31, 2013 | 03:06 PM
pzoom's Avatar
Car: 91 Firebird Convertible
Engine: 305 TBI
Did you get the car fixed and what part failed? Thanks!
Old Oct 23, 2016 | 10:14 PM
Anthony0128's Avatar
Old thread but did you ever find the problem cause I'm having the same issues and I can't seem to find what it is
Old Oct 23, 2016 | 10:36 PM
Old Oct 24, 2016 | 09:04 AM
pzoom's Avatar
Engine: 305 TBI
My car had rough idle, surging, no power.
My fix was the hose on fuel pump as RS-Chevy-SS mentioned above. I guess GM thought the pump would fail long before the hose. Mine was all eaten up even though the car only has 50K miles on it. I ended up replacing the entire fuel pump assembly.
Old Oct 24, 2016 | 10:20 AM
I switched out my pump a while back and I put on a new hose whIle doing it. What I think might be wrong is the hoses connected (fuel lines) I might have not connected them correctly the return line and canister line might be wrong. Could it cause the vehicle to stall ?
Falcon50
Aug 22, 2020 03:26 PM
db057
Jan 10, 2020 08:55 PM
Fireslash
Apr 11, 2016 06:43 PM
Gordonr1973
Sep 29, 2015 11:59 AM
Bigold4x4
Sep 28, 2015 05:21 PM
